Tip & How-To about Sony Playstation 3 (PS3) Console
How to fix Ps3 error code 80710723
Ok so your trying to complete a download off some sort on your playstation three and no matter how many times you switch your playstation three on/off, its not working?! Here is a step-by-step instructon guide on how to fix this error.
Firstly turn on your playstation console, select your user account. Then when you enter the main playstation menu screen, Scroll to "settings" and enter. When you get to settings, scroll down untill you see the icon "internet settings" if you scroll down even after that yo will see "media server" you will have a option to disable/enable. Well simply disable it and go and complete your download, then follow the process to enable it again. Now the issue you having is solved.
Sony Playstation 3 (PS3) Console Logo
My PS3 has sort of the same problem , but instead I can no longer switch back to HDMI nor do I have any sound from my AV Cables.
Your a/v settings need to be reset. When turning on your console, buy the button located in front of the disk drive, hold it down until you hear it beep once, and continue holding it down until it beeps three time in quick succession. Your console will reset the video setting to default 480p and a prompt will appear for the settings closely matching your tv. Select ok and your resolution will change. From there, when it loads to the xmb, go to the left until you hit the column settings, and go down to audio output settings. From there, chose the option audio multi-output and make sure it's on. Should resolve your issue.
Nov 04, 2013 | Sony Playstation 3 (PS3) Console
ps3 it will not let you sign in checked internet its ok when we try the screen displays you are disconnected from playstation network , router is also ok
hi its not a problem your end sony are having some problems with their network just give them time to sort it out and then you should have no problems click on the link below for more details
CLICK HERE
this problem affects ps2 ps3 psp and the problem is world wide
this problem will be sorted as soon as possible you could try contacting sony direct to find out how long the downtime is going to be please dont change ant settings on your console as the problem is with them and not your console.
give them time this will be sorted out soon
Mar 01, 2010 | Sony PlayStation® 3 (80GB) Console
registration of trophies information was not completed on ps3
ok first off just know that there is a playstation network problem so the trophys is jus keep going into the game
no matter how much it sends you out
i hope ive helped
I cannot get into any games or into many of the worlds on the Playstation Home. When I try to go somewhere like the Central Plaza it tells me "Your profile character is unable to download this screen". What is the problem
CLICK HERE
Jan 09, 2010 | Sony Playstation Home
psp wont power up
what u've done is u've bricked ur PSP
when ur downloadinig an update, it copies files to a very important folder called flash0(u cant access w/o modifying ur psp, and even then, i don't recommended that u do)
in order to fix, ur gonna need to know sumone with a hacked psp and a spare battery
then read this article
Jun 26, 2008 | Sony PlayStation Portable (PSP) Console
754 people viewed this tip
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
