Tip & How-To about Computers & Internet
Replacing a Desktop's Graphics Card
In order to replace your Graphics card, you will need:
A screwdriver that fits the bolts of the casing of your computer
A new Graphics Card that is compartible to your Motherboard
And computer knowledge.
Start by removing drivers of your old Graphics card, by starting up the Device Manager from the Control Panel. Expand "Display Adapters", and double click on your Graphics card. On the Driver tab of the window that opens, click Uninstal, and follow the installshield wizard (could be automatic or might be another wizard).
After your Drivers are removed, shut down your computer, and remove the cable from your PSU. Make sure that your computer is not connected to anything that provides power to it.
-You might want to use insulating gloves for this task-
Start by removing one of the sides of the casing by unscrewing the bolts. It should be fairly easy to understand how to remove it after the bolts are removed.
When looking at your motherboard, your graphics card should be placed near the back of your computer. If you are unsure which card(if there are many) is the old Graphics Card, see where the Monitor's cable goes in.
Carefully unscrew any bolts that are used to lock your graphics card on the computer casing.
After that is done, remove all cables attached to your graphics card from inside the computer, and then carefully pull the Graphics Card out, making sure that your card is safe. After that is done, place your new Graphics card in the slot of your old one, and connect any wires connected to it(if needed).
Then do all the things you did to your computer backwards.
After your graphics card is ready and installed, start up your computer and insert it's manufacturer's disc. If you do not have a disc, look up on the internet.
Install the drivers, and it's ready for use.
Computers & Internet Logo
PC screen problem: do I need a new graphics card (where to find?) or is it a driver or other problem?
I had that once but so long ago I can't exactly remember the cause.
I think I replaced the graphics card.
If my memory is correct I was sure it was the graphics card because my pc had on-board graphics that had been disabled because a graphics card had been fitted so I removed the card, transferred the video lead and restarted and it worked ok, just not as well. I replaced the graphics card and it was fine.
If your pc has on-board graphics that is currently being used, it probably means the motherboard is defunct, though fitting a graphics card in an expansion slot could render it usable once more.
Jul 25, 2016 | Graphics Computers & Internet
need new graphic card but cant find one compatable
Hello. The best solution for your graphic card replacement is, in my oppinion, ASUS ATI RADEON 9550 GE. It is 128-bit series model, and it is better with 128MB of memory, because with 256MB is much more expensive, but almost no difference.
Best wishes, SteveTM
May 28, 2011 | Nvidia GeForce4 MX 440, (64 MB) Graphic...
Suggestions for new graphics card on Gateway 300s
just check what motherboard version your computer is running on and just advise the supplier to supply you with a graphics card that well fits for that motherboard.....
Oct 11, 2009 | Gateway (6000736) (4 MB) Graphic Card
can i fit a new graphics card
Graphics chips on laptops are usually part of the motherboard and therefore cannot be changed.
Your only choice is to get a new and usually a better laptop.
Most desktop computers can accomodate new graphics cards by installing them in AGP or PCI slots, most modern graphics are AGP type cards.
Nov 14, 2008 | Computers & Internet
149 people viewed this tip
David Payne
David Payne
