Tip & How-To about Computers & Internet
Keyboard shortcuts for Microsoft Windows XP, Vista, 7 and Microsoft Office
Windows
Windows Key+E
This shortcut allows you to open Windows Explorer with one quick keystroke.
Alt+Tab
This allows you to easily toggle back and forth between all the windows you have open. You can also use this to switch between windows in the same program, making multitasking real easy.
Windows key+Tab
This lets you scroll the items on the taskbar, and in Vista, it starts Flip 3D for a fun graphical spin on the same idea.
Alt+F4
This shortcut is a quick way to close a window in any program without using your mouse to hit the X in the upper-right corner.
Windows Key+M
This allows you to minimize all of your open windows, leaving just the desktop left exposed. To restore the windows, hit Windows key+Shift+M. Another quick way to do this is Windows key+D, which shows your desktop; to restore, just repeat the same keystroke.
Ctrl+Drag
There are many ways to copy a file, but this just might be the easiest. All you have to do is click on the file, hold, and drag it into its desired location. This works the same as another handy shortcut, Ctrl+C.
Windows Key+U+U
This is the shortcut for quickly shutting down Windows by hitting the Windows key (don't hold it down), hitting U to reach the shutdown menu, and then hitting U again to shut down.
Windows Key+Pause
This is a quick way to get to the Systems Properties menu.
Shift+Delete
If you want to delete a file-and you don't want to deal with it later in the Recycle Bin-this is the way to go. Just be absolutely sure that this is a file you won't want back!
To bypass the Autorun when inserting a CD
Hold Shift While Inserting the CD.
Microsoft Office
Ctrl+U, Ctrl+B, Ctrl+I
Used to snap to underline, bold, and italicize without the mouse if you press Ctrl+U (underlining), Ctrl+B (bolding), or Ctrl+I (italicizing).
Shift + Arrow Keys
Holding shift and pressing one of the arrow keys will highlight text in Word (or a group of Excel cells) without the mouse, selecting in the direction the arrow points.
Ctrl+Z, Ctrl+Y
Undo an action by hitting Ctrl+Z; if you change your mind, Ctrl+Y will redo the undo.
Microsoft Office - Excel
F1
Opens a help task pane
F1 + Ctrl
Opens or closes the help window
F2
To edit the text in the active cell
F2 + Shift
To write a comment in the active cell
F2 + Alt
Opens the save as dialog box
F3 + Shift
Opens the insert dialog box
F3 + Ctrl
Opens the define name dialog box
F3 + Shift + Ctrl
Opens the create name dialog box
F4
To redo the last command
F4 + Ctrl
To close the workbook window
F4 + Alt
To close the excel program
F5
Opens the Goto dialog box
F5 + Ctrl
brings back to the first level of workbook
F6
To shift between help taskbar and the excel window
F6 + Shift
To goto the previous square in the open worksheet
F6 + Ctrl
If more than one workbook is open to switch between them
F7
To open spelling correction window
F7 + Ctrl
When workbook window is not maximised it will move the window
F8
To activate / deactivate extended mode
F9
Will calculate all the worksheets in all open workbooks
F9 + Shift
Will calculate the active worksheet
F9 + Ctrl
To Minimise the workbook window
F10
Will select the menu bar
F10 + Ctrl
To open minimised window
F11
Will create a chart using the current range
F11 + Shift
To select a new worksheet
F11 + Alt
To switch between visual basic editor and the worksheet
F11 + Alt + Shift
Opens microsoft script editor
F12
Opens save as dialog box
F12 + Shift
Saves the active workbook
F12 + Ctrl
To open the Open dialog box
F12 + Ctrl + Shift
Opens the print dialog box
Computers & Internet Logo
Keyboard Shortcut for Windows
Getting used to using your keyboard exclusively and leaving your mouse behind will make you much more efficient at performing any task on any Windows system. I use the following keyboard shortcuts every day:
Windows key + R = Run menu
This is usually followed by: cmd = Command Prompt iexplore + "web address" = Internet Explorer compmgmt.msc = Computer Management dhcpmgmt.msc = DHCP Management dnsmgmt.msc = DNS Management services.msc = Services eventvwr = Event Viewer dsa.msc = Active Directory Users and Computers dssite.msc = Active Directory Sites and Services Windows key + E = Explorer
ALT + Tab = Switch between windows
ALT, Space, X = Maximize window
CTRL + Shift + Esc = Task Manager
Windows key + Break = System properties
Windows key + F = Search
Windows key + D = Hide/Display all windows
CTRL + C = copy
CTRL + X = cut
CTRL + V = paste
Also don't forget about the "Right-click" key next to the right Windows key on your keyboard. Using the arrows and that key can get just about anything done once you've opened up any program.
Keyboard Shortcuts
[Alt] and [Esc] Switch between running applications
[Alt] and letter Select menu item by underlined letter
[Ctrl] and [Esc] Open Program Menu
[Ctrl] and [F4] Close active document or group windows (does not work with some applications)
[Alt] and [F4] Quit active application or close current window
[Alt] and [-] Open Control menu for active document
Ctrl] Lft., Rt. arrow Move cursor forward or back one word
Ctrl] Up, Down arrow Move cursor forward or back one paragraph
[F1] Open Help for active application
Windows+M Minimize all open windows
Shift+Windows+M Undo minimize all open windows
Windows+F1 Open Windows Help
Windows+Tab Cycle through the Taskbar buttons
Windows+Break Open the System Properties dialog box
acessability shortcuts
Right SHIFT for eight seconds........ Switch FilterKeys on and off.
Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.
Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.
SHIFT....... five times Switch StickyKeys on and off.
NUM LOCK...... for five seconds Switch ToggleKeys on and off.
explorer shortcuts
END....... Display the bottom of the active window.
HOME....... Display the top of the active window.
NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.
NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.
NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.
LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.
RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.
Type the following commands in your Run Box (Windows Key + R) or Start Run
devmgmt.msc = Device Manager msinfo32 = System Information cleanmgr = Disk Cleanup ntbackup = Backup or Restore Wizard (Windows Backup Utility) mmc = Microsoft Management Console excel = Microsoft Excel (If Installed) msaccess = Microsoft Access (If Installed) powerpnt = Microsoft PowerPoint (If Installed) winword = Microsoft Word (If Installed) frontpg = Microsoft FrontPage (If Installed) notepad = Notepad wordpad = WordPad calc = Calculator msmsgs = Windows Messenger mspaint = Microsoft Paint wmplayer = Windows Media Player rstrui = System Restore netscp6 = Netscape 6.x netscp = Netscape 7.x netscape = Netscape 4.x waol = America Online control = Opens the Control Panel control printers = Opens the Printers Dialog
internetbrowser
type in u're adress "google", then press [Right CTRL] and [Enter] add www. and .com to word and go to it
For Windows XP:
Copy. CTRL+C Cut. CTRL+X Paste. CTRL+V Undo. CTRL+Z Delete. DELETE Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE Copy selected item. CTRL while dragging an item Create shortcut to selected item. CTRL+SHIFT while dragging an item Rename selected item. F2 Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROW Move the insertion point to the beginning of the previous word. CTRL+LEFT ARROW Move the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROW Move the insertion point to the beginning of the previous paragraph. CTRL+UP ARROW Highlight a block of text. CTRL+SHIFT with any of the arrow keys Select more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keys Select all. CTRL+A Search for a file or folder. F3 View properties for the selected item. ALT+ENTER Close the active item, or quit the active program. ALT+F4 Opens the shortcut menu for the active window. ALT+SPACEBAR Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4 Switch between open items. ALT+TAB Cycle through items in the order they were opened. ALT+ESC Cycle through screen elements in a window or on the desktop. F6 Display the Address bar list in My Computer or Windows Explorer. F4 Display the shortcut menu for the selected item. SHIFT+F10 Display the System menu for the active window. ALT+SPACEBAR Display the Start menu. CTRL+ESC Display the corresponding menu. ALT+Underlined letter in a menu name Carry out the corresponding command. Underlined letter in a command name on an open menu Activate the menu bar in the active program. F10 Open the next menu to the right, or open a submenu. RIGHT ARROW Open the next menu to the left, or close a submenu. LEFT ARROW Refresh the active window. F5 View the folder one level up in My Computer or Windows Explorer. BACKSPACE Cancel the current task. ESC SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing.
Use these keyboard shortcuts for dialog boxes:
To Press Move forward through tabs. CTRL+TAB Move backward through tabs. CTRL+SHIFT+TAB Move forward through options. TAB Move backward through options. SHIFT+TAB Carry out the corresponding command or select the corresponding option. ALT+Underlined letter Carry out the command for the active option or button. ENTER Select or clear the check box if the active option is a check box. SPACEBAR Select a button if the active option is a group of option buttons. Arrow keys Display Help. F1 Display the items in the active list. F4 Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE
If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts:
Display or hide the Start menu. WIN Key Display the System Properties dialog box. WIN Key+BREAK Show the desktop. WIN Key+D Minimize all windows. WIN Key+M Restores minimized windows. WIN Key+Shift+M Open My Computer. WIN Key+E Search for a file or folder. WIN Key+F Search for computers. CTRL+WIN Key+F Display Windows Help. WIN Key+F1 Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ L Open the Run dialog box. WIN Key+R Open Utility Manager. WIN Key+U
accessibility keyboard shortcuts:
Oct 19, 2008 | Computers & Internet
Windows XP HELP Windows key + R = Run menu cmd = Command Prompt iexplore + "web address" = Internet Explorer compmgmt.msc = Computer Management Windows key + E = Explorer ALT + Tab = Switch between windows ALT, Space, X = Maximize window CTRL + Shift + Esc = Task Manager Windows key + Break = System properties Windows key + F = Search Windows key + D = Hide/Display all windows CTRL + C = copy CTRL + X = cut CTRL + V = paste Keyboard Shortcuts [Alt] and [Esc] Switch between running applications [Alt] and letter Select menu item by underlined letter [Ctrl] and [Esc] Open Program Menu [Ctrl] and [F4] Close active document or group windows (does not work with some applications) [Alt] and [F4] Quit active application or close current window Ctrl] Lft., Rt. arrow Move cursor forward or back one word Ctrl] Up, Down arrow Move cursor forward or back one paragraph [F1] Open Help for active application Windows+M Minimize all open windows Shift+Windows+M Undo minimize all open windows Windows+F1 Open Windows Help Windows+Tab Cycle through the Taskbar buttons Windows+Break Open the System Properties dialog box explorer shortcuts END....... Display the bottom of the active window. HOME....... Display the top of the active window. Type the following commands in your Run Box (Windows Key + R) or Start Run devmgmt.msc = Device Manager msinfo32 = System Information cleanmgr = Disk Cleanup ntbackup = Backup or Restore Wizard (Windows Backup Utility) excel = Microsoft Excel (If Installed) msaccess = Microsoft Access (If Installed) powerpnt = Microsoft PowerPoint (If Installed) winword = Microsoft Word (If Installed) frontpg = Microsoft FrontPage (If Installed) notepad = Notepad wordpad = WordPad calc = Calculator mspaint = Microsoft Paint wmplayer = Windows Media Player control = Opens the Control Panel Internetbrowser type in u're adress "google", then press [Right CTRL] and [Enter] add www. and .com to word and go to it For Windows XP: Copy. CTRL+C Cut. CTRL+X Paste. CTRL+V Undo. CTRL+Z Delete. DELETE Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE Copy selected item. CTRL while dragging an item Rename selected item. F2 Move the insertion point to the beginning of the previous paragraph. CTRL+UP Select all. CTRL+A Search for a file or folder. F3 View properties for the selected item. ALT+ENTER Close the active item, or quit the active program. ALT+F4 Opens the shortcut menu for the active window. ALT+SPACEBAR Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4 Refresh the active window. F5 Cancel the current task. ESC
Oct 12, 2010 | Computers & Internet
209 people viewed this tip
David Payne
David Payne
