Tip & How-To about Video Game Consoles & Games
Pitching Tips
Hold A and B buttons to throw a 'splitter' ball. This ball is difficult to hit and strikes out people because it's aimed at their feet.
How To Throw A Strike-Out Pitch:
Hold down the 2 button, and the left or right button (not at the same time) to throw a strike-out ball. For instance, if you hold down the 2 button, the pitch will be low and harder for the batter to hit.
How To Get A Red Bat:
Hold the A, 1, and 2 buttons while the screen is loading, and your bat will turn red.
How To Pitch Underhand:
Hold down the 2 button to throw an underhand ball. Switch back to pitching overhand by pressing the 1 button.
Video Game Consoles & Games Logo
What's a straight ball release?
This is actually my favorite throwing style. What you need to dois to grab the ball with you hand creating a "w" shape, then you need to aim tothe center lane and a click to the left and powerfully throw the ball asstraight as you can in the direction you've aimed to, try practicing it alittle bit to master this throw.
Jul 23, 2012 | Sport & Outdoor - Others
i cant remove my lower ball joint from a 98 nissan sentra
now i know this sounds bad but first thing is to throw that away ,,, next open nut on balljoint and then take a hammer and if you are a fella with good aim ,, strike the little housing that the balljoint is stuck in ,,,, a experienced mechanic can do it in 2 to 3 srtikes so theres a challenge for you!!!! seriously if you can hit it hard and have good aim it will come apart easy ,,,, modern stuff is alloy but yours is steel so you can hit it hard and do no harm ,,, once you dont beat the hell out of any thing else ,,,
Feb 13, 2012 | Nissan Pickup Cars & Trucks
How do you throw the ball?
hold the B button or as some people call it the trigger button swing your arm like you would in regular bowling and as you would release the ball you let go of trigger or b button and it should work
Jan 21, 2010 | Crave Entertainment Brunswick Pro Bowling...
I need written instructions for EA Sports MVP Baseball for Gamecu
hope these are the right ones
MVP Baseball 2005
BATTING
Z Button Z + A Button = Square to Bunt (release to pull back)
A Button Swing
BASERUNNING
Control Pad Steal / Choose base destination (press toward base you are trying to steal)
Slide Refer to EA SPORTS Big Play Control in Gameplay below.
C Stick Left/Right = Increase/decrease leadoff.
X Button Control runner at 1st
B Button Control runner at 3rd
Y Button Control runner at 2nd
L Button Advance/stop all runners
Z Button Advance/stop all runners
R Button Retreat runner
PITCHING
Control Stick Choose pitch location.
A Button Throw a pitch
X Button Throw a pitch
B Button Throw a pitch
Y Button Throw a pitch
White Button (press and hold) + Directional Pad Up/Down (Left/Right to toggle between bullpens and dugouts) = View Bullpen/Dugout menu
R Button Throw a pitch
L Button + X, B or Y = Pickoff attempt. L + A = Pitchout. L + Control Pad Down = Intentionally hit the batter. L + Control Pad Up = Intentionally walk a batter.
Z Button (Hold) + Control Pad Up/Down = Choose infield/outfield alignment (before pitch). Left/Right to choose a category. Z Button (hold) + C Stick Left/Right = View pitch history, to toggle at bats. Z Button + Control Pad Up/Down = View Bullpen/Dugout menu (Left/Right to toggle between bullpens and dugouts).
FIELDING
Control Stick Move fielder
C Stick EA SPORTS Big Play Control
A Button Throw to home (press and hold to power up, release to throw)
X Button Throw to 1st (press and hold to power up, release to throw)
B Button Throw to 3rd (press and hold to power up, release to throw)
Y Button Throw to 2nd (press and hold to power up, release to throw)
R Button Throw to the cut-off man
GamePlay:
EA SPORTS PURE SWING SYSTEM:
The Strike zone is divided into nine colored squares. Red squares mark the batter's hot zones. Blue squares are the batter's cold zones. Clear squares are neutral for the batter.
Take unprecedented control at the plate by moving the Control Stick during your swing.
-The results of your swing depend on your timing, the location of the pitch, and the direction you move the Control Stick.
-For the best results, move the Control Stick towards the location of the pitch.
-To hit the ball in the air, move the Control Stick Diagonal Up-Left / Up / Diagonal Up-Right while swinging. This increases the chances of hitting a fly ball, but also increases your chances of missing the ball if the pitch isn't up in the zone.
-To hit the ball on the ground, move the Control Stick Diagonal Left-Down / Down / Diagonal Right-Down while swinging. Keep in mind that high pitches are very difficult to hit on the ground.
-To hit the ball to the left, move the Control Stick Diagonal Left- Down / Left / Diagonal Up-Left while swinging. For the best results, use this when the pitch is coming in on the left side of the plate.
-To hit the ball to the right, move the Control Stick Diagonal Right-Down / Right / Diagonal Up-Right while swinging. For the best results, use this when the pitch is coming in on the right side of the plate.
TO THROW A PITCH:
1. Press and hold the button that corresponds to the pitch you want to throw. The bar inside the pitch meter begins moving.
2. Release the pitch button when the bar reaches the end of the pitch meter. The closer your release point is to the end of the meter, the more effective the pitch is.
3. Press the pitch button again when the bar is within the green accuracy zone near the beginning of the pitch cycle to determine the pitch's accuracy.
-The effect of a bad pitch depends on the type of pitch. For example, ineffective fastballs are slower than normal, and less effective breaking pitches are flatter.
-If a pitcher misses the green accuracy zone by a considerable amount, an indicator (red for hot zone, blue for cold zone, yellow for ball, white for neutral) appears to tip off the batter to the location of the pitch.
PITCH SELECTION
Your pitcher's pitch selection appears on-screen. Not all pitchers have the same arsenal of pitches. A pitcher's four-seam fastball is always assigned to A Button. The remaining pitches are assigned to X, B, Y and R Button (though not all pitchers have five pitches).
FIELDING
-If you power up the throw into the red zone, you throw harder, but less accurately, which could result in an error.
-If you select to throw to either a base or the cut-off man before the ball arrives, the fielder begins his throw immediately upon receiving the ball.
NOTE: The CPU automatically adjusts your defensive alignment based on the situation. However, you can override this by choosing the infield and outfield alignments yourself.
EA SPORTS BIG PLAY CONTROL:
Using the all-new EA SPORTS Big Play Control, you can climb the fence to rob home runs, make spectacular diving catches, slide around tags, and more.
FIELDING:
- To dive or stretch for a ball just out of your reach, move the C Stick Left/Right toward the ball.
-To climb the wall to snag a would-be home run or jump for a ball over your head, move the C Stick Up.
-To make a sliding catch, move the C Stick Down as the ball approaches.
BASERUNNING
Timing is the key to a perfect slide. Use EA SPORTS Big Play Control to create havoc on the base paths.
C Stick:
Up = Head-first slide
Diagonal Up-Left/Up-Right = Head-first slide to the left/right side of the bag
Down = Pop-up slide
Diagonal Down-Right/Down-Left = Hook slide to the right/left side of the bag
Up = Dislodge ball from catcher.
May 19, 2009 | EA Sports MVP Baseball 2005 for GameCube
495 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
