Tip & How-To about Lands Phones
Any phone Hard reset
HARD RESETHard reset is an operation that turn the device into default manufacturer,like the first use a new phone, it will wipe and delete all of your software,data,sitting and virus.if you can't turn on or process device sitting,You still can do the hard reset by instruction below,hope it will help you.........All Hard reset process need to turn device off/except iPhone4 .Make sure that ur phone is full battery and turn off,you can release the battery if necessary.... HTC/Windowsmobile=>press and hold volume up and down,including press power on/off button.you will see an automatic operation press volume up to hard reset or other to cancel./was tried on HD2 and Touch2,work very well.HTC/Android =>While turn off process,hold home+back button,including power button.then release home and back button,you will see an android hard reset operations and follow the in struction...IPhone 3G,3Gs, IPod Touch,IPad...=>- Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously .- Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart . You may release all button when you see the silver Apple logo .For IPhone4 is no need to turn off as normally=>-press and hold on/off+sleep/wake button to turn off,until see an automatic operation-slide across the red slider-hold two button above to turn on...* Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen .Nokia/Touchscreen with keyboard/N97,N97 mini,...=>Press and hold button shift/left+space+backspace,including power button and follow in struction...Nokia Touchscreen nonkeyborad/5800,5530,5230,5233,5802,X6,C6...=>Press and hold green+red+camera shot button,including power on/off until boot up./was try on Nokia 5800 and 5530,no problem....* for N8 =>press volume down+camera+menu,including power button...Nokia nontouchscreen/N70,N71,N80,N95,N96,N82,N95,E52,E71E71x,E72,6300,5320,5220,5130,6120,6303,6500,6730,8800....../S60=>Press and hold green,*,3 button,including power on/off button.../was tried on Nokia N81 and,no problem,work very well.* For Nokia,if the operation require code,the default code is 12345.* S80 press and hold Ctrl+shift+F* S40 is not available hard reset by button.can do by type *#7370#,and available for S60 too.BlackBerry=>Press and hold Alt+Shift/right+Del,then follow the instruction...SonyErisson/Touchscreen with keyboard=>Press and hold right + left soft key,including press power button.../was try on X1i,no problem...SonyErisson/Nontouchscreen: Not available hard reset by button...need the future research.You should know that Hard reset is the last solution,if none solved ur mobile problem.Note: all above just a part and not 100% correct.No guarentee for data lose or any demage.Do by your own risk-kindly do not edit this document.... :)Research and Prepare by YEKCHHUNHOUR.Inform me if you see any wrong instructions,to improve this doc better and confiding.Via Email: Chhunhour.kh@hotmail.com27/12/2010 VOTE FOR ME PLZ..........
Lands Phones Logo
my htc p3400 phone attack vairas then corrept phone os give me solution haw to format my phone
Hi. You need to HARD reset your phone.
To perform a hard reset (Full Reset) press and hold the left SOFT KEY and the right SOFT KEY, and at the same time, use the stylus to press the RESET button at the middle left side of your device.
Release the stylus, but continue pressing the two SOFT KEYs until you see the following message on the screen:
This operation will delete all your personal data, and reset
all settings to manufacturer default. Press Send to restore
manufacturer default, or press other keys to cancel.
Release now the two SOFT KEYs, and then press the TALK (Send) button
Thank you for using fixya
May 25, 2011 | Computers & Internet
I have an HTC touch HD phone and I'm having a problem trying to put in my passward; because every time when I would put in the passward it will tell me its incorrect and I can not get into my phone but I can only recieve calls; and I have tried to reset the passward but still no success. Please help me ....what should I do??
You are now in session with aziz_carew
Ekse says:
to get rid of the password, we must wipe the device clean
Ekse says:
with a hard reset
Ekse says:
Have you performed a reset? A normal reset will not remove the password
Ekse says:
To perform a HTC Touch HD hard reset
Ekse says:
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
Ekse says:
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
Ekse says:
This operation will delete all your personal data, and reset all settings to the manufacturere default settings, press Volup to restore manufacturer defaults or press any other keys to cancel
Ekse says:
3. Release the VOLUME UP and VOLUME DOWN buttons.
Ekse says:
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Oct 29, 2009 | HTC Touch HD Smartphone
i cant use my camara it says failure to set up camra device
Perform a soft reset of your phone and then check if the camera works again or not? To perform the soft reset, insert the stylus in the reset pinhole. In case you get the same error after the soft reset, then you might need to perform the hard reset, but before hard resetting the device, bakup all the information (contacts, messages, appointments, calender entries) as all the data would be lost and phone would return to factory defaults. To perform Hard Reset:
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel.
3. Release the TALK and END buttons, and then press ENTER on your device.
Oct 28, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
iam sooraj using HTC P400i PHONE MY MOBILE NUMBER +919946324460(PREPAID VODAFONE) I CANNOT USE GPRS IN MY MOBLIE PLS HELP TO BROWSE BY GIVING MANUUAL SETTINGS
This will wipe all the storage (not the sd card) and your device will be reset to default settings.
Hard reset (option 1)
  1. Pull out the stylus.
  2. With the device turned on, press and hold the VOLUME DOWN and CENTER buttons, then press the RESET button with the stylus tip.
  3. Continue pressing the RESET, VOLUME DOWN and CENTER buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press ?VolUp to restore manufacturer default, or press other keys to cancel.
Hard reset (option 2)
You can also use Clear Storage to reset your device back to factory default settings.
  1. On the ?TouchFlo3D Home screen, slide to the Settings tab and then tap All Settings or goto Start and press Settings.
  2. On the System tab, tap Clear Storage.
  3. Enter “1234” and then tap Yes.
Hard reset (option 3)
  2. Turn device OFF.
  3. While pressing the CENTER button, turn the phone on with the POWER button.
  4. Continue pressing the CENTER button until you see this message on the screen:
This works on at least some Verizon CDMA phones on which option 1 will not work.
Hard reset (option 4)
  2. With the device turned off, press and hold the VOLUME DOWN and CENTER buttons, then press and hold the POWER button.
  3. Continue pressing the POWER, VOLUME DOWN, and CENTER buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press ?VolUp to restore manufacturer default, or press other keys to cancel. (works with Alltel touch pro)
Sep 29, 2009 | HTC Touch P3450 Smartphone
how do i hard reset the htc p4600?
  2. Turn device OFF.
Sep 29, 2009 | HTC Touch Diamond Smartphone
1,192 people viewed this tip
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
