Home | All Products | AL1912 (White) 19" LCD Monitor | Tips
Determine if you are having problems with your monitor or video card in...
BobbyR1234
By Guru BobbyR1234
Rank: Guru
Rating: 88%, 409 votes
posted on Jul 07, 2008
Helpful
Many people have problems determining if their monitor is bad or their video card is bad. One good way to test this is by swapping out your monitor with a friend, co-worker, or family member with a known good monitor. You can do this with either your computer tower or your monitor. Follow the two steps below:
1. Take your computer tower and plug it up to a known good monitor. If the computer boots up with no problems and you are able to see everything on the known good monitor, then your monitor is bad.
2. Take a known good monitor and plug in to your computer system. If the computer boots up and you are still having problems and getting a black screen or some message saying "no signal" then your are having problems with your video card.
Some common symptoms of a monitor going bad are as follows:
1. A humming or buzzing noise coming from your monitor.
2. Picture fades in and out.
3. Colors appear in various places on your monitor screen that normally would not be there. Most common colors presented are red, green, or a mixture of the two.
4. Picture presenting either light or dark and will not change no matter how much you change the color or tint setting.
5. Lines appearing on the monitor screen. These will look like the lines on a bad television.
6. Monitor takes longer than normal to present picture. This time can vary depending on how old your monitor is and how far into the malfunction phase it is.
Since your monitor works off the same principles as your television set, most the time it will present with the same symptoms as a television going bad. I hope this helps in your troubleshooting process to determine if your video card or your monitor is the one causing the problems. These symptoms apply to the regular monitor only and not necessarily an LCD monitor.
Comment by BobbyR1234, posted on Jul 08, 2008
Since they do not let you edit these tips by the person who posted them, I just want to add that they can apply to an lcd monitor, but the post is meant for the regular monitors and I just mis-worded it.
Was this helpful?
Yes
No
6 people thought this was helpful
Comment #1
posted on Jun 07, 2009
zer0five_o5
By Apprentice zer0five_o5
Rank: Apprentice
Rating: 0%, 0 votes
uh.. so what ca i do to fix my monitor if it has gone bad?..
Comment #2
posted on Jan 07, 2009
fchehov
By Apprentice fchehov
Rank: Apprentice
Rating: 0%, 0 votes
I have a Viewsonic Q2201WB monitor. I am not sure if this problem is related to my monitor or some other hardware (ie display card, motherboard,etc). Over the last couple of months I have noticed that when I change pages during browsing or working with programs such as Excel, Outlook, Word that a banner or menu title becomes fixated and stays on the screen no matter where I am at.
If anyone has experienced this problem and has a solution or fix I would appreciate your input. Note the monitor is about five months old and the computer about 1.5 years old. This did not happen with the prior monitor. My wife uses this computer to play Napster or Pandora music while she works on her own computer. Just thought I would add that tidbit just in case it could have some impact on this problem.
Thank you in advance for your expertise and assistance.
Comment #3
posted on Jul 25, 2008
GSAN
By Guru GSAN
Rank: Guru
Rating: 90%, 69 votes
Great tips you are providing here Bobby1234. These tips reallt make it easier to explain problems that are common and repetitious on many of these forums. I'll see what I can do to help as well in the near future.
Can you Help with these Monitors problems?
Acer AL1912 (White) 19" LCD Monitor
desktop monitor light blinks when powered on but the...
Not to computer smart. Looking for new unit all the wires...
my monitor pops up a stupid dialog box every 2 minutes or...
Can't lower the brightness
I change the 10V 1000uf capacitors but steel my monitor...
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
