Tip & How-To about Computers & Internet
Tips For Mac Laptop Repair
If you are accomplishing the assignment yourself, again about-face off the laptop afore isolating the devices. As anon as, the absurdity is detected, chase for tips to adjustment the corresponding laptop part.
You can consistently use the abreast adjustment to analyze the botheration with your laptop. This Mac laptop adjustment adjustment involves abatement of one accessory at a time so that you can agenda the operation of laptop afterwards analysis the device. If the laptop starts working, again the alone accessory is amenable for the abnormal functioning.
Firstly, analyze the operational affair with the laptop and acquisition the cure for it. Go through mackintosh album or Mac laptop adjustment websites. You can acquisition several laptop adjustment tips on the Internet. The footfall by footfall action works finer for the adjustment task. You can additionally booty advice of a abstruse able to analyze the laptop adjustment issue.
Computers & Internet Logo
bluetooth peripheral device driver missing
You should install the driver software for your Bluetooth module built in. Check the CD or DVD(If came with your laptop) and install the driver from it. Then update it.
If you don't have any CDs or DVDs came with your laptop, go to the official website of the manufacturer of your laptop and download the drivers by yourself
Otherwise, you can visit the retail shop you bought your laptop and ask from them for the drivers.
Jun 12, 2017 | Cell Phones
Installing Devices on PCs and Laptops
I have uninstalled and reinstalled many many times with no success.I did get it to print a alignment page a few times.but no doc printed.
Dec 02, 2009 | Computers & Internet
says warming up but then get scanner failure message
Friend, You need to reinstall the device as the scanner portion of the drivers are malfunctioning. Please read the following and act accordingly:
Although there is a wizard to install devices on your PC or laptop, but still there are problems being faced by users. The reason is that there is a logical procedure for installations. Read on.
There are two things that you install. The drivers for all the devices and the program to use that device for some. First of all insert the CD that came with the device into the CD drive and let Autorun takeover. You will be guided throughout the process. Just answer a few questions and the SW will start the installation process for drivers. Once drivers have been installed then you can proceed with the installation of the program needed to run the device, not for all devices. After this task is accomplished always reboot the computer/laptop.
After the reboot, attach the device to the PC. Windows will immediately start the detection process and on detection will load its drivers that you had just installed. And then a notice appears in the right bottom corner of the screen saying "The new hardware was successfully installed and is ready for use". Or words to that effect. Now you can start using the new device whether through its specific program or through other programs that are meant to use it.
There are times when you are reinstalling the drivers. In that case you must first uninstall the old drivers and reboot the PC/laptop. Uninstall it from Control Panel->Add Remove Programs. And then reboot and reinstall.
Apr 20, 2011 | HP OfficeJet K80 All-In-One InkJet Printer
USB device does not recognised and pen drive doesn't show its symbol. and my windows drivers are all of up dated. Help me please
There are a few possibilities for the problem you're having. Some you can resolve yourself, some you will need further assistance from a professional.
It sounds like you've done some basic diagnostics already so don't worry if these steps start off with things you've already done.
First, with the kingston drive connected, open my computer and see if the drive shows up at all, if it does click on it and see what messages come up. If you receive a message regarding hardware failure the device is likely damaged, if you receive a message telling you the device is not formatted then you have do it yourself methods available to recover any files before you format the drive.
Second, open device manager and select the Kingston, if you're not sure how right-click on your Computer or My Computer icon and left-click Manage. Once the management console opens, left-click device manager on the left panel, then expand **** drives section and identify the Kingston, if it's not there the hardware has failed beyond do it yourself techniques. If it is double click the Kingston to open it's properties sheet. Select the Volumes tab and then click the populate button. If it shows up with approx 2GB then do it yourself methods will likely work, let me know and I'll point you to a specific article to walk you through the process, if it shows up with an absurd size or fails to detect a volume let me know and I will get you a referral into a nearby data recovery facility(please supply Country, State and City).
Either way we'll get your files if it's worthwhile. If the volume does show up in Device manager and your have no need to recover files from the device, you should be able to then select disk manager from the left panel, find the Kingston and format it to get it working again.
Hope this helps Fixya,
Chris
Dec 19, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Whenever I turn on my laptop I get the Error: Resource Conflict-PCI Network Controller on Motherboard Bus:08, Device:00, Function:00 Bus:08, Device:01, Function:00
You have a device that is attempting to use the same IRQ as another device that has loaded before it. Go into the device manager and look for a device that has a yellow triangle with an exclamation mark inside. You may find a couple.... Open the device properties and see if you get some indication of which other device it is having conflicts with. Then it is a matter of uninstalling one of the devices and rebooting, letting Windows re-detect the device and install it again...hopefully with the correct IRQ assignment this time.
Feb 17, 2010 | HP OmniBook XE3 Notebook
292 people viewed this tip
David Payne
David Payne
