Tip & How-To about Dryers
Troubleshooting Gas Dryer Problems
Drum Spins, But No Heat
  • Check the burner and the controls to see if they are faulty. Adjust the air shutter to readjust the air flow. Loosen the screw on the air shutter and move the shutter until the flame looks light blue in color.If this doesn't work, have the dryer serviced. Other problems could be the timer, thermostat or centrifugal switch, all of which can be replaced.
  • Motor On, But Drum Doesn't Turn
  • Replace the worn or broken drum belt that spins the drum. The idler and motor pulleys that spin the belt, the tension spring and the roller that the drum rides upon may also be causing the problem. Try tightening the motor pulley. Have the parts replaced, or the motor serviced.
  • Slow Drying Time
  • Clean out the exhaust vent, the exhaust paths and the lint screen.Check the door and drum seals to see if they are worn. If damaged, have the seals replaced. Replace the thermostat if it is faulty. Adjusting the air shutter may correct the problem.
  • Dryer Gets Too Hot
  • Unclog the exhaust vent and clean the lint screen. This holds in theheat instead of allowing it to pass out of the dryer. Make sure thatthe exhaust vent is installed properly. Try adjusting the air shutter.If the thermostat is faulty, have it replaced.
  • Dryer Makes Noise
  • Tighten any loose parts that shake as the dryer operates. Replace the worn belt, idler pulley or support rollers. The noise could also be a loose blower that will need to be fixed or replaced. Noise can also indicate that the motor bearings are damaged; if this is the case,service the motor.
  • Dryer Doesn't Operate
  • Check the power cord to determine if it is unplugged or damaged. If the door switch, thermostat, timer, motor switch or start switch is damaged, have it replaced. If the motor-overload protector was activated due to too many clothes in the dryer, let the machine restated cool down for 15 minutes.
  • Posted by on
    Dryers Logo
    heater is not igniting
    see this causes and fix it. God bless you
    f there is no heat, check the electrical service panel for a burned fuse or tripped breaker. Relight the pilot light (see below). If there is not enough heat, adjust the burner air shutter (see below); and clean the burner ports (see below).
    If the pilot light does not light or does not stay lit, clean the pilot orifice carefully with a toothpick, test the thermocouple and replace it if it is faulty (see below).
    If the flame flickers, adjust the pilot (see below).
    If there is an exploding sound when the burner ignites, adjust the pilot to a higher setting and clean the pilot orifice and the burner ports.
    If the burner takes more than a few seconds to ignite, clean the pilot orifice and adjust the pilot light.
    If the burner flame is uneven, clean the burner ports. If the burner flame is very yellow, clean the burner; open vents in the furnace room to provide more air; adjust the burner air shutter.
    If the furnace makes a rumbling noise when the burners are off, clean the burner and adjust the burner air shutter.
    If the air is too dry, wash or replace the evaporator pad if you have a humidifier; test the humidistat; and adjust the water-level float to raise the water level.
    If some rooms are too cool and others too warm, the distribution system may require balancing. Refer to the Forced-Air Distribution Fix-It Guide .
    Oct 08, 2012 | Intertherm Heating Cooling System 15kw...
    RHFE Rinnai 551FT gas heater is not working after 7 years
    see this steps and fix it. God bless you
    If there is no heat, check the electrical service panel for a burned fuse or tripped breaker. Relight the pilot light (see below).
    To light the pilot on a standing-pilot (always on) ignition system, follow the lighting instructions located near the control. Otherwise, try these steps:
    Light the pilot:
    1. gasfurnace1.jpg Press and hold the pilot control knob to start the pilot. Set the control knob to the pilot position. Hold a long match under the pilot gas port.
    2. Press the control knob; the pilot should light. Hold the control knob down until the flame is burning brightly (about 30 seconds). Release pressure on the knob, and turn it to the on position.
    3. If the pilot goes out when you release the control knob, try relighting, holding the control knob down longer. If the pilot again goes out, check the thermocouple (below).
    Adjust the pilot:
    1. Remove any cap covering the pilot adjusting screw on a combination control.
    2. Turn the adjusting screw counterclockwise to increase the flame or clockwise to decrease it. It is correctly adjusted when the flame envelops the thermocouple bulb by 1/2 inch and appears dark blue with a small yellow tip.
    Test and replace a thermocouple:
    1. Hold the control knob to pilot and light the pilot as above.
    2. Unscrew the thermocouple fitting with an open-ended wrench.
    3. Set a multimeter to the DVC (lowest voltage) scale.
    4. Clip one multimeter lead to the end of the thermocouple tube nearest the pilot and the other lead to the fitting on the other end of the tube.
    5. If the multimeter shows a reading besides zero, the thermocouple is functioning. Replace the thermocouple tube.
    6. If there is no reading, you will need to clean or replace the thermocouple following steps 7 through 11.
    7. Release the control knob and shut off the main gas valve on the gas-supply pipe that leads into the burner. Shut off power to the burner at the electrical service panel .
    8. Remove the thermocouple from its mounting bracket.
    9. Wipe the combination control clean and install a new thermocouple, tightening it by hand, then give it a one-quarter turn with a wrench.
    10. Insert the thermocouple into the pilot bracket, being careful to not crimp the tubing.
    11. Turn on power to the furnace and relight the pilot (above).
    Adjust an adjustable burner air shutter:
    1. Set the thermostat to its highest setting to keep the burner running. Once the furnace has heated up, remove the burner access panel and loosen the locking screw.
    2. Open the shutter by turning it to the right until the blue base of the flame appears to lift slightly from the burner port surface. Then close the shutter until the flame reseats itself on the surface.
    Clean removable burner tubes and ports:
    1. Shut off gas and power to the furnace.
    2. Unscrew or loosen and remove the tubes from the supporting bracket.
    3. Carefully clean the tubes with a brush or vacuum, making sure not to damage the burner ports.
    4. Use a stiff wire to clear any debris from clogged ports.
    Sep 30, 2012 | Heating & Cooling
    Flame does not seem hot enough - too much yellow flame.
    In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
    To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
    Jan 05, 2009 | Kenmore 63942 Dryer
    gas dryer
    hi
    Gas dryers use an electric ignition device rather than a pilot light to light the gas heater: An element becomes hot and glows like the filament in a lightbulb. Electric ignition systems are always sealed; you can't adjust or repair them. If an electric ignition device fails, call a professional service person for replacement.
    In a gas dryer, heat is provided by a gas heater, controlled by an air shutter.
    Electric dryers have self-contained electric heating elements.
    Sep 14, 2008 | Dryers
    369 people viewed this tip
    Top Dryers Experts
