Tip & How-To about Computers & Internet
Increase the downloads with IE 7.0
1. Click "Start" => "Run"and type regedit.
2. Once in the registry editor, find the value: "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings"
3. Right click on empty space create a new DWORD entrybyselecting
= New> DWord Value
Name the new registry key:"MaxConnectionsPer1_0Server"
4. Double-click the new key and change the value by 3 (or any other value, it will be your maximum number of simultaneous downloads)
5. Create a new DWORD key in the same way with the name
MaxConnectionsPerServer
Computers & Internet Logo
how to Log on into administrator account
1. In the Start Menu, select Run.
2. In the Run dialog, type 'regedit' without quotes, to start the registry editor.
3. Navigate to the key,
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \Winlogon \SpecialAccounts \UserList
4. In the right pane, right click and select, New > Dword
5. A new item will be created, right click on it and rename it to 'Administrator'.
6. Then double click on the Administrator item and enter a value, '1' in the dialog box.
7. Close registry editor and restart your computer, you can see the Administrator account listed in the Login Screen.
Dec 27, 2011 | Computers & Internet
When installing Norton Ghost 15.0 onto a XP machine I get the following error message. "Error 1606. Could not access network location 0\."
This is a fairly common problem in Windows XP, especially with SP2. The most common method that fixes it is to delete some registry keys.
Click on Start-Run, type regedit (without the quotes) Navigate to this registry path:
HKEY_CURRENT_USER --> Software --> Microsoft --> Windows --> Current Version --> Explorer --> User Shell Folders
Clear the key: Recent (right mouse click on the key/folder, choose Delete) Close the Registry Editor and restart the computer.
Apr 15, 2011 | Symantec Norton Ghost 14.0: Windows
pan drive is write proction
From Start menu, point to Run, type in: regedit
If you are using Vista or Windows 7, just type in regedit in the search box when you click on the Start menu.
Navigate to the key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\
Find a sub key inside that is named "StorageDevicePolicies". If it does not exist there then we need to make it. Right click on "Control" key -> New -> Key. Name it "StorageDevicePolicies" without quotes.
Now right click on this newly created key and then click New -> DWORD value and name it as "WriteProtect".
5
Double click this key to modify and give it a value 0. The value 1 in here means to enable it, while the value 0 is the opposite to disable it.
6
Click OK button to save and exit Registry Editor.
Thanks.
Have a great day.
Oct 11, 2010 | Computers & Internet
when typing numbers< signs are appearing instead of numbers>>>it"s like it"s stuck in caps!
need to do the two procedure:
  1. Go to Start>> Run. Type in: regedit [Enter] or click OK.
  2. Navigate to the following registry key:
    HKEY_CURRENT_USER\Control Panel\Keyboard
  3. Click the "keyboard" entry once to empty its contents into the right pane.
  4. Find a string entry titled "InitialKeyboardIndicators".
  5. Double click this entry and change the Value to either '2' for on,
  6. Exit the Registry Editor and reboot your system for the changes to take effect.
    HKEY_USERS\.DEFAULT\Control Panel\Keyboard
    InitialKeyboardIndicators = 2
Mar 26, 2010 | Fujitsu Siemens AMILO Pro V7010 Notebook
my system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
181 people viewed this tip
David Payne
David Payne
