Tip & How-To about Office Equipment & Supplies
Solve Error:49.2f9d error of HP LaserJet Printer
49.XXXX is a critical firmware error. It may be caused by a bunch ofthings such as bad input data or data corruption due to poor cables.
From the service manual :-
Recommended action
1. Press CANCEL JOB to clear the print job fromthe printer memory.
2. Turn the printer off, and then turn the printeron again.
3. Go to http: www.hp.com/support/lj2410, www.hp.com/support/lj2420, or www.hp.com/support/lj2430.
Click DownloadDrivers and Software.
Check for thelatest firmware image version at the bottom of the page.
If this firmwareimage is newer than the one installed on the printer and the printer canreceive a firmware update, download the newer firmware upgrade.
Not all printermodels can receive firmware upgrades.
4. Try printing a job from a different softwareprogram. If the job prints, go back to the first program and try printing adifferent file. If the message appears only with a certain software program orprint job, contact the software vendor for assistance.
Hope this helps
HP color laserjet error code 49, we turn off the printer when it asks us to but still has an error on it. No clue what is wrong
From the HP Website
ERROR 49.XXXX
A critical firmware error has occurred that caused the processor on the formatter to abort the operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs. Remove all EIO devices and firmware DIMM if installed. Restart printer. If error is gone replace each EIO device until error appears. Replace device which triggers error. May also be formatter. Firmware updates are available for some machines at http://hp.com and clicking on the drivers and software tab. Also try printing from a different application. If that works go back to the first application and try printing a different file to determine if the problem is file related. You may need to reseat the memory DIMM's or replace the firmware DIMM or formatter board.
Jul 15, 2011 | Office Equipment & Supplies
49, 4c02 error in hp 4250
This is what the result for that error code is:-
ERROR 49.XXXX
Feb 08, 2011 | HP LaserJet 4250dtn Printer
my printer hp lj 3005 in error code 49.2f9d please solve my problem
49.XXXX is a critical firmware error. It may be caused by a bunch of things such as bad input data or data corruption due to poor cables.
Recommended action
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on again.
3. Go to http: www.hp.com/support/lj2410, www.hp.com/support/lj2420, or www.hp.com/support/lj2430. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update, download the newer firmware upgrade. Not all printer models can receive firmware upgrades.
4. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
Hope this helps
Dec 29, 2010 | HP LaserJet P3005 Printer
error 49.420c
first try to upgrade the firmware
second try a cold reset
if this dont work change the formatter
Aug 06, 2008 | HP LaserJet P3005 Printer
49.2F80
Normally it is fro corrupt data or bad cables.
49.xxxx error explain.
operations.
to the printer. Other causes include poorquality
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 Service error
Dec 19, 2007 | HP LaserJet 4350 Printer
2,515 people viewed this tip
jasbo
jasbo
