Tip & How-To about Computers & Internet
How to connect to wifi? step1
Open the Start menu.
- In "Connections", click on "Show all connections":
- Right click on the icon "Wireless Network Connection"
- Click on "properties":
- Click the second tab "System networks without son. "
- In the "Preferred Networks"click on "Add ..."
Computers & Internet Logo
how do i reset it my wireless adapter
If I were you, I'd first let Windows Manage Wireless Network Connections:
  1. Click Start If you're using XP, click Start then open the Control Panel. Find the Switch to Classic View button in the Control Panel and click it.
  2. Open Network Connections Open Network Connections then double-click the Wireless Network Connection icon.
  3. Click the Properties Click the Properties button. Look for the boxes at the bottom of the Properties window that read "Show icon in notification area when connected" and "Notify me when this connection has limited or no connectivity" and make sure they are both checked.
  4. You could also right click on the Wireless Network Connection icon and click Properties from there.
  5. Open Wireless Networks tab Open the Wireless Networks tab and make sure the box labeled "Use Windows to configure my wireless network settings" is checked. Then click OK.
  6. under Control Panel\Network and Internet\Network and Sharing Center you could find "manage wireless connection" there you could assign/delete wireless connection.
Oct 26, 2014 | Lenovo ThinkCentre M72E 4004-B8U Tiny Form...
cant get on the internet
If you have win xp operating system then you can follow instruction to resolve your issue
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
hope this will help you
Thanks for using Fixya
Jun 12, 2010 | NetGear WNA1100 WirelessN 150 USB Adapter...
how do i connect to my livebox c240 using a netgear wpn311
following steps can fix your issue(only for XP)
ENABLE WZC
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
Mar 14, 2010 | NetGear WPN311 108 Mbps 802.11g RangeMax...
Turn on the wireless switch without using without using Fn Key?
  1. Click the "Start" button, then click the "Control Panel" icon on the Start menu. This opens the Control Panel window.
  2. Step 2 Click the "Switch to Category View" link in the left-side pane of the Control Panel window if the window is not already set to category view. You will see the "Network Connections" icon in the right-side pane. Double-click this icon to open the Network Connections window.
  3. Step 3 Right-click the icon for your wireless network adapter in the Network Connections window, then click the "Properties" link in the context menu. This opens the Wireless Network Connection control panel.
  4. Step 4 Click the "Wireless Networks" tab in the Wireless Network Connection control panel. Check the box next to "Use Windows to configure my wireless network settings."
  5. Step 5 Click the "OK" button in the Wireless Network Connection control panel. This completes the process.
Dec 02, 2009 | Office Equipment & Supplies
unable to connect netgear wg111 adaptor to orange livebox for internet connection
Hi, follow the steps below:
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
4. Highlight thee SSID from the list that you want to connect to.
Aug 31, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
361 people viewed this tip
David Payne
David Payne
