Tip & How-To about Maytag Neptune MDG5500AW Gas Dryer
My maytag neptune dryer would not warm up
My 2 yr old Maytag dryer took forever to heat up. called the repairman and I found out that when the company I bought the dryer from installed it they kinked the duct hose. Solenoid was replaced but burnt out since the duct when obtructed. You might want to pull the dryer out and check the hose.
Maytag Neptune MDG5500AW Gas Dryer Logo
Electric dryer stopped in the middle of a cycle of towels (or after they were dry...not sure, as renters reported problem). . There appears to be no current..panel does not light at all Have reset the circuit breakers, unplugged and replugged the 220, but nada.The model is Kenmore Elite Mod 110 62042100.
My 4 yr. old Maytag electric dryer stopped in the middle of drying towels and wouldn't restart. I called one repairman who told me it was my motor and I called another repairman closer to where I live and he came out and replaced my fuse. My dryer works fine now.
Aug 17, 2011 | Kenmore 63942 Dryer
My Neptune dryer has stopped heating. Is there
Dryers are very simple. You probably just need a new heater element. Usually just remove the back panel, remove the element, take it to a appliance parts store, get a new one and install it. They don't cost very much maybe $20 or so...
Jul 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Fabric seal on Maytag Neptune dryer coming out.
Give this site a try. Some guy on the forum had the Neptune issue and found a replacement seal. There are some how-to videos on YouTube(may not be your specific dryer, but same idea.) I'll let you have the joy of looking on YT.
Maytag Neptune Dryer MDE9700AYW Felt Drum Liner
Jan 25, 2018 | Maytag MDE9700AYW Neptune 174 Electric...
maytag dryer performing inconsistantly
you either need a new heating element or you are not getting full 240 volts, im assuming its electric here. check your outlet to make sure both leads are hot.
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Where can I buy the dryer belt?
I bought my dryer belt dirrectly from Danby. They first gave me the name of a company to get it from, when I called them, I was told they no longer handled Danby. So I called Danby back, the woman I talked with was very helpful. She ordered the belt and sent instructions on how to change the belt out myself, and said if I had any problems with the installation, give them a call. It took me about two and a half hourse to replace the belt. But if I had to do it again I think I could do it in 30 to 45 min. By the way I'm a 60yr old woman.
Sep 29, 2008 | Danby DCD5505W Electric Dryer
1,993 people viewed this tip
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
