Tip & How-To about Computers & Internet
Medion laptop battery. Difficult today to escape the laptops. They are now part of everyday life and make us proud service. But be careful to choose a brand. Indeed, some brand like laptop batteries medion are quite difficult to find, is less well you can find by searching on the Internet on sites specialized.
Computers & Internet Logo
where can i buy battery for medion S4209 (md98148}?
The only place I found was the official Medion shop. The item is here
http://www.medion.com/gb/prod/MEDION%C2%AE+Laptop+Battery/40040608A1 (Art-No. 40040608A1)
This is the battery for S46XX/S42XX models.GBP42.95 + GBP6.95postage (UK prices) Check if it looks right, and that the voltage (nominal 11.1V) is right. There may be other numbers on your battery such as p/n which will verify for certain (you may like to search on the internet by the other numbers to see if anything turns up that is better value). You will have to look on other Medion sites (choose country selector from page given) to obtain local information.
Contact support here
https://www.medion.com/gb/service/contact/
to check this is the correct battery, to be absolutely certain.
4.May.2014
May 03, 2014 | Medion Computers & Internet
no battery life
Yes the battery is probably getting weak. If you get a model number you can probably find one on ebay. Here is a link for Medion batterys.
http://shop.ebay.com/i.html?_kw=medion&_kw=battery&_ckw=notebook
Dec 14, 2009 | Medion MD 40812 Notebook
how do i override the password on my medion notebook laptop?
I assume you are referring to a system (hardware) password that you are challenged for when powering up the laptop, not the operating system password. You can just reinstalll the O/S into another folder to get access to the system and all the data files ...
Two types of system passwords exist;
1 type is the password stored in an area of the mainboard that is called CMOS (Complementary Metal-Oxide Semiconductor) a completely fancy way of saying an area whoes data is kept alive by a battery. You need to know if your model laptop uses a CMOS battery and how you can disconnect it. Go to the manufactures website at: http://www.medion.co.uk/ . If you can pull the battery for 30 minutes or so, then you may erase the password.
2 If you have a system that writes this password to a non-destructive area of the systems memeory in order to prevent data theft, you have a more difficult time removing the password. Some Lenovo systems must swap out the main board. the password cannot be accessed. Try the battery if you can, else Google medion laptop hacks
Oct 13, 2009 | Medion md40298 Notebook
i need to change the power jack at the back of my medion mim2120. can anyone guide me through the process please and are the sockets available on ebay suitable, I've seen them as low as £3.50 including post and packing.
Yes you can get the adapters from eBay but make sure when you search for one you search by your laptop model to make sure you purchase the correct one.
Now i don't know what make or model your laptop is so guiding you through the process will be difficult but it's basically the same.
You will need to disassemble the laptop to get to the motherboard and remove it so you can start work, this can be difficult to do and many people end up with screws left over and don't know where they go, a good idea is to draw a life sized sketch (basically draw round the laptop twice on paper) to map out where you took certain screws from and where the major components go.
Once you have the motherboard out you can de-solder the old adapter and solder in the new one.
NOTE: there are delicate ribbon cables underneath the keyboard and possibly in other locations so take care when you are disassembling the laptop.
If you need anymore help post back.
Good luck.
Aug 20, 2009 | Computers & Internet
184 people viewed this tip
David Payne
David Payne
