Tip & How-To about Computers & Internet
Remove Recycle Bin From Desktop
ø Click Start Menu
ø Click on Run
ø Type "Regedit" and click OK
ø Navigate to the following key
ø HKEY_LOCAL_MACHINE
ø SOFTWARE
ø Microsoft
ø Windows
ø CurrentVersion
ø explorer
ø Desktop
ø NameSpace
ø Click on the "Recycle Bin" string in the right hand pane. Hit Del, click OK.
Computers & Internet Logo
how do i disable incognito in chrome
First, open the registry editor:
  1. Open the Start menu
  2. In the search box, type "regedit"
  3. A program called regedit.exe will appear, click on this
  4. If a warning comes up click Yes
Next, navigate to the Policies key:
  1. Start by double clicking on "Computer"
  2. Then, double click on "HKEY_LOCAL_MACHINE"
  3. Next, double click on "SOFTWARE"
  4. Finally, double click on "Policies"
Next, create a new entry called IncognitoModeAvailability:
  1. Right-click on "Policies" and select New >> Key
  2. Enter "Google" (without the quotes) as the name of the key
  3. Right-click on "Google" and select New >> Key
  4. Enter "Chrome" (without the quotes) as the name of the key
  5. Right-click on "Chrome" and select New >> DWORD (32-bit) Value
  6. Enter "IncognitoModeAvailability" (without the quotes) as the name
  7. Right-click on "IncognitoModeAvailability" and select "Modify..."
  8. Type a 1 in the "Value Data" text box
  9. Click OK and exit the Registry Editor program
Restart Google Chrome and now if you open the settings menu, the "New incognito window" option will be disabled.
Feb 14, 2015 | Dell Inspiron Computers & Internet
How do I disable InCognito mode turn off
https://www.internetsafetyproject.org/wiki/how-disable-incognito-mode-chrome
Dec 18, 2014 | Acer AC700-1099 Chrome book Wi-Fi
pan drive is write proction
From Start menu, point to Run, type in: regedit
If you are using Vista or Windows 7, just type in regedit in the search box when you click on the Start menu.
Navigate to the key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\
Find a sub key inside that is named "StorageDevicePolicies". If it does not exist there then we need to make it. Right click on "Control" key -> New -> Key. Name it "StorageDevicePolicies" without quotes.
Now right click on this newly created key and then click New -> DWORD value and name it as "WriteProtect".
5
Double click this key to modify and give it a value 0. The value 1 in here means to enable it, while the value 0 is the opposite to disable it.
6
Click OK button to save and exit Registry Editor.
Thanks.
Have a great day.
Oct 11, 2010 | Computers & Internet
i cant change the company name i bought this register from someone else not the company casio
you can do this by using following the below steps:
1. Click Start, Run and type regedit, and then click OK. Navigate to the following location: HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion 2. To change the registered organization, double-click RegisteredOrganization.
3.Under Value data, type the name that you want, and then click OK.
4.To change the name of the registered owner, double-click RegisteredOwner.
5.Under Value data, type the name that you want, and then click OK.
6.Click Exit on the File menu to quit regedit.
or u can use this link to download a tool to do the job automatically
http://windowsxp.mvps.org/utils/ChangeOwner.exe
Jan 23, 2010 | Casio Parts Cash Register PC Desktop
201 people viewed this tip
David Payne
David Payne
