Tip & How-To about Cell Phones
How can flash nokia 3230 phone
Remove memory card and format it in computer. format ur cell also. this can be done by first switch off cell. Then restart by pressing all three keys simultaneously namely "the green call key","pencil key" and "3 key" along with ur start button at top. Keep it pressed till u get the format screen. Before doing this charge the cell fully. Before this backup everything in your computer or memory card. This must work.
Cell Phones Logo
my n73 phone starts with installation and says application not supported everytime.
just update ur fone firmware OR hard format ur n73... by following method:
(note : b4 u do any of the above solution remove the password of memory card and also take the backup of ur memory card through Nokia pc suite not by using cardreaders....)
hard format :
remove memory card
switch off the fone
now press call key(green) + 3 + * key
keep on pressing all three keys and switch on the fone ... dont release the keys untill the fone boots on....
the fone settings will be restored to its default... also all d security codes of fone will be retored to defaults....
now ur problem is solved .... put ur memory card back.... n if it still asks for memory card unlock password ... then jus format it .....through fone..... it wont ask again.....
regards
Bhumit
Feb 03, 2009 | Nokia N73 Cellular Phone
Nokia N73 hanging
it generally hangs when u install new new softwares in it, which is sometimes not compatable with ur mobile platform.
now what u have to do is u have to format ur phone to factory settings that is the only way which is to be done in regard to make ue phone run smooth
sometime when u talk for long hours on ur cell fone , it gets heat up and ur call get automatically disconnected.
u have to reset it which is sometimes dangerous to ur cell phone, it might cause some harm to it.
There r two ways to format ur Cell Phone
1. Soft Core Format
2. Hard Core Format
1. In Soft Core Format u have to dial *#7370#    or   dial  *#7780#     this will format ur phone memory and u have to manually format ur memory card
2. In Hard Core Format ur mobile gets formatted as a tough format,     u have to keep on pressing the three buttons simultaneously(at the same time) for a long period unless u get a screen on ur phone when it asks for the region(ur country).
what u have to do:
1. switch OFF ur mobile
2. u have to press three keys at a time
    Call Button (green key) + * key + 3  at the same time
3. now dont get ur fingers off those buttons , ask someone to switch ur mobile ON (if possible make       ur cell phone placed on some table for stability) (please dont move ur fingers off those three keys       unless u get the screen where u r asked for ur region)
once u got that screen ur cell phone is formatted
NOTE: Formatting the phone with HARD CORE FORMAT METHOD may be harmful if not done in the correct way
Pls Vote for me if this solution works for u
Thank You
Vinay Ramani
India
Sep 17, 2008 | Nokia N73 Cellular Phone
formsttong n72
There r two ways to format ur Cell Phone1. Soft Core Format
2. Hard Core Format
what u have to do:
Doing HARD CORE FORMAT might help u in resetting the password.
Thank You
Vinay Ramani
India
Sep 08, 2008 | Nokia N72 Cellular Phone
Nokia N95 Automatic Restart, Hanging, Shutting Down
1. Soft Core Format
2. Hard Core Format
what u have to do:
Thank You
Vinay Ramani
India
Jun 30, 2008 | Nokia N95 Cellular Phone
Hoe to format nokia N70 mobile
Answer from:::::::::::::: [VJ]'s
(Firstly coppy all contacts from the phone to SIM card)
1.Switch off the phone.
2. Press and hold the following three buttons:
Green(call answer) button, (*) button, (3) button.
3.Now press the switch on button.
4.Then the message 'Formatting" appears on the screen releas all buttons
Oct 04, 2007 | Nokia N70 Cellular Phone
119 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
