Tip & How-To about Office Equipment & Supplies
How to install Local Printer?
To add Local Printer follow some steps:
  1. Open control panel window by clicking start button. Click on printer and faxes from control panel window.
  2. Click add a printer which will be seen in printer tasks the sub window.
  3. To which type of printer you want to install, click on next button.(Here the printer is Local Printer or Network Printer.).
  4. Select "Local printer attached to this computer".Further, if "automatically detect and install my plug and play printer" does not selected then select it and click next.
  5. To install printer manually click next.
  6. Select an appropriate port from drop down list and click the next button.
  7. Select the printer name which you will used to install in your computer.
  8. Type name of your printer.
  9. If you want to share your printer with other then select share otherwise select do not share.
  10. If you want to test your print.Select print a test page.
  11. If all procedure will be done then click on finish button.
the printer is showing the message offline,how to reslove this
Please click on start on the computer----Control Panel-----printers and Faxes.
Please right click on the printer icon and click on use printer online.
Then again, click on the printer icon and click on cancel all documents.
The issue will be fixed.
If still you are not able to print, pleae follow the below steps.
Click on Start on the computer---- and in the search box or RUN type "services.msc" and hit enter.
Here you will see an option "print spooler".
Just stop that print spooler
and then restart that spooler.
This will make it print.
If still you are not able to print, please follow the below steps.
FOR XP operating system
Click on start button on computer then control panel then printer and faxes.
Click on the option of Add a Printer and click on Next on the Wizard.
On the next page select the option of Local Printer and uncheck the option of Plug and Play devices.
On the next page, select the option of Use Existing Ports and select the option of USB Virtual Port and click on Next.
On the next page, select HP as the manufacturer and Deskjet 990c as the printer.
Verify the printer name and set the printer as default then click next.
Select print a test page option.
Click on Finish.
FOR VISTA operating system.
Click windows logo and go to Control Panel.
Click on Printers.
Click Add a printer. This launches the Add Printer Wizard.
Click Add a local printer.
Now, Use the drop down arrow to select USB port 001 then click Next.
Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
Click on Finish.
Jul 03, 2010 | HP Deskjet D1560 InkJet Printer
Suddenly the HP PSC 1600 is printing at supe slow speeds
TRY THIS
first try to copy something to check that the hardware function is fine if copy comes out fine try the following step
click on start button go to control panel open printers and faxes select your printer name right click on it and go to properties click on advance tab now select print processor and select WINPRINT and then RAW
now click ok and try printing
if still does the same thing then goto control panel printers and faxes and then click on add a printer select ADD A LOCAL PRINTER now select existing potr and select usb 001 click next select the brand HP and then DESKJET 990c in the printer list click next give your printer name and select set as default now click next and finish the installation now try printing
Jul 30, 2009 | HP PSC 1610 All-In-One InkJet Printer
Am having problem installing my hp laserjet6p printer
just check out the instructions its for both inkjet and laser printers. When installing a new printer with the Add Printer Wizard, you can choose between adding a local printer (one that's directly cabled to your computer through one of the ports) or a network printer (a printer that's connected to your network with an Ethernet connection, just as your computer is connected to the LAN).
To install a new local printer with the Add Printer Wizard, follow these steps:
1. Click the Start button on the Windows taskbar and then click Control Panel on the right side of the Start menu.
2. Click the Printers and Other Hardware hyperlink if the Control Panel window is in Category View.
Otherwise, double-click the Printers and Faxes icon if the Control Panel window is in Classic View.
3. Click the Add a Printer hyperlink in the Printers and Other Hardware window to start the Add Printer Wizard and then click the Next button, or press Enter to advance to the Local Printer or Printer Connection dialog box.
4. Make sure that the Add Printer Wizard selects the Local Printer radio button, and the Automatically Detect and Install my Plug and Play Printer check box beneath this radio button before you click the Next button.
5. If the wizard is unable to detect your printer in the New Printer Detection dialog box, click Next to install the printer manually.
6. Select the port for the printer to use in the Use the Following Port drop-down list box in the Select a Printer Port dialog box and then click the Next button.
7. Click the manufacturer and the model of the printer in the Manufacturers and Printers list boxes, respectively, of the Install Printer Software dialog box.
If you have a disk with the software for the printer, put it into your floppy or CD-ROM drive and then click the Have Disk button: Select the drive that contains this disk in the Copy Manufacturer's Files drop-down list box and then click OK.
8. Click the Next button to advance to the Name Your Printer dialog box.
If you want, edit the name for the printer in the Printer Name text box. If you want to make the printer that you're installing the default printer that is automatically used whenever you print from Windows or from within a Windows program, leave the Yes radio button selected beneath the heading, Do you want your Windows-based programs to use this printer as the default printer?
9. Click the Next button to advance to the Printer Sharing dialog box.
If you want to share this printer with other users on the network, click the Share Name radio button and then, if you want, edit the share name (this is the name that the other users on the network see when they go to select this printer for printing their documents) that the wizard gives the printer in the Share Name text box.
10. To print a test page from your newly installed printer, click the Yes radio button selected beneath the heading, Would you like to print a test page? in the Print Test Page dialog box.
11. Click the Next button to advance to the Completing the Add Printer Wizard dialog box, where you can review the settings for your new printer before you click the Finish button or press Enter to finish installing the new printer.
To use the Add Printer Wizard to install a printer that's available through your Local Area Network, you follow just slightly different steps:
2. Click the Printers and Other Hardware hyperlink if the Control Panel window is in Category View. Otherwise, double-click the Printers and Faxes icon if the Control Panel window is in Classic View.
3. Click the Add a Printer hyperlink in the Printers and Other Hardware window to start the Add Printer Wizard and then click the Next button or press Enter to advance to the Local or Network Printer dialog box.
4. Click the A Network Printer or a Printer Attached to Another Computer radio button in the Local or Network Printer dialog box and then click the Next button or press Enter to the Specify a Printer dialog box.
5. If you know the name of the network printer, click the Connect to This Printer (or to Browse for a Printer, Select this Option and click Next) radio button and then enter the network path in the Name text box.
If your network printer is on a network that uses an Internet address and you know this URL address, click the Connect to a Printer on the Internet or on a Home or Office Network radio button and then enter the address in the URL text box. If you know neither of these pieces of information, leave the Browse for a Printer radio button selected and then click Next to advance to the Browse for Printer dialog box.
6. In the Browse for Printer dialog box, locate the printer in the Shared Printers list box by clicking the network icons until you expand the outline sufficiently to display the printer icon.
When you click the printer icon in this outline, the wizard adds the path to the Printer text box above.
7. Click the Next button to advance the Default Printer dialog box.
8. Click the Next button to advance to the Completing the Add Printer Wizard dialog box, where you can review the settings for your new printer before you click the Finish button or press Enter to finish installing the new printer.
After you add a printer to your computer, you can start using it when printing with programs such as Word 2002 and Excel 2002, or when printing from Windows itself.
To switch to a new printer that you haven't designated as the default printer in programs such as Word and Excel, you need to open the Print dialog box (choose File-->Print) and then select the printer name in the Name drop-down list box.
Feb 02, 2009 | HP LaserJet 6p Printer
epson stylus c46
Go here: http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20C46-_E
You can get the user guide as well as a setup guide.  If this helps please rate my solution.  Thanks
Dec 11, 2008 | Epson Stylus C46 InkJet Printer
I have a H-P Compaq Presario A900 Notebook PC and it came with a Canon Pixma MX310 all in one printer. It has windows vista 2007 on it (computer) and one of the instructions says to open the vista program and I don't understand what that means. Also the printer did'nt come with a usb cable. I have wireless internet if that matters. I don't understand how to hook it up to the computer and I followed the instructions. Help
To install the printer do this:
Nov 23, 2008 | Office Equipment & Supplies
185 people viewed this tip
jasbo
jasbo
