Tip & How-To about Radio Communications
Understand the Benefits of Each Two Way Radio Battery?
Li-ion batteries are lighter than NiCd or NiMH batteries while still accouterment ample power. Because they don't accept any memory, Li-ion batteries are not accessible to "memory effect" (see below).
NiMH batteries accommodate no baneful metals and are beneath adverse to the ambiance than NiCd batteries.
NiCd batteries accept a continued acceptability for reliability. They can handle aerial endless and assignment able-bodied in two way radios and added accoutrement that crave a lot of power.
Radio Communications Logo
dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
Feb 28, 2015 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Can I use a de 9116 charger for a 18 v 1.3hbattery please
Yes, it's charger for batteries from 12V-18V, but only NiCD and NiMH. Do not use it for charging Li-ION batteries. What type of battery you have should be stated on the battery itself.
Regards, Juraj
Dec 02, 2014 | Electrical Supplies
battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
http://www.aulaptopbattery.com.au
Oct 05, 2012 | Computers & Internet
makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
1,372 people viewed this tip
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
