Tip & How-To about Computers & Internet
Laptop battery does not charging
Following could be the reasons for such failure:-
Computer AC/DC cable is bad not allowing the computer battery to charge
Verify that the AC/DC cable is not bad by removing the battery from the laptop and seeing if the computer can power on without the battery.
Battery is bad and/or old
If the power plug is good it's likely that your laptop battery is bad. If you're using a laptop with Microsoft Windows consider getting and installing BatteryCare on the computer to look at the total capacity of the battery.
Try leaving the laptop connected to the power with the battery inserted for at least two hours. If the battery still doesn't seem to charge, i suggest having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty i suggest replacing the battery as it's very likely that it is just a bad battery.
Battery charger board is bad
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It's recommended that the laptop be sent in to be repaired.
Computers & Internet Logo
My Acer 5315 will not charge I plug it up an nothing happens no charging light, or anything what do I need to do?!
Hello
If the computer and/or battery is not in warranty we suggest replacing the battery as it's very likely that it is just a bad battery.
Hope it helps, if so do rate the solution
Dec 24, 2010 | Acer Aspire 5315 Notebook
my battery will not charge
Hello Following issue could be possible
Issue:Main computer battery does not charge.
Cause:This issue can be caused by any of the below possibilities.
  1. Computer AC / DC cable is bad not allowing the computer battery to charge.
  2. Battery is bad.
  3. Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Aug 18, 2009 | Computers & Internet
when i plug in my charger to my laptop it doesnt work and i dont know whats wrong with it
This issue can be caused by any of the below possibilities. 1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
2.- Battery is bad
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 14, 2008 | Computers & Internet
BATTERY NOT PRESENT
If that is an old battery , it only means that the battery is already dead and needs a replacemenet, but if that battery is new make sure that the battery is charging if its not changing the prokblem can be the battery still....
Hope that helps...........
Sep 18, 2008 | Compaq NC8000 Notebook
395 people viewed this tip
David Payne
David Payne
