Tip & How-To about Office Equipment & Supplies
Inkjet Printer Tips
In general, most inkjet printers print well on any type of paper, but occasionally lower quality paper can reduce the printer's output and cause paper jams.
The majority of inkjet printers appear withcomputer application for charwoman and adjustment the heads. It is appropriate that you run these at atomic already a month. Keeping your printer armament active clean, will accumulate your printer active smoothly.
Avoid abrogation the printer armament cradle empty. Never abolish the old armament until you are accessible to install the fresh one.
One of the best tips for befitting your printer active calmly is to use it regularly. Lack of use can accord out poor affection printing.
Single paper sheet not printed, multiple yes
Try few steps as given below...
1. poor quality printer may reduce printer quality & causes paper jams and other printer problems. If you encounter problem , switch to a higher grade of printer.
2. Do not load curled and paper folder.
I hope, it helps.
Feel free to get instant printer help at http://www.vtechsquad.com/printer-support/ to fix any printer issues.
Jan 21, 2013 | Epson Stylus Photo R800 InkJet Printer
I am using quickbooks 2005 and am trying to print full page checks. I am getting a 'paper mismatch' error and cannot print my checks.
Welcome to FixYa.
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error.
How do you load your check in the printer?
Keep me posted.
Jas247
Jun 15, 2011 | HP Photosmart 8250 InkJet Printer
want to speed it up
There are several things that may cause you printer to be slower than advertised. Click on control panel and then click on printers and right click on your 5550 and you'll see a drop down menu. Then select printer preferences. You'll see a screen with several tabs. go to paper/quality and click on it and make sure you have 'default printer settings' in the little window near the top and then look at Print Quality near the lower left--make sure this is set on Normal, fast Normal or draft. This should help speed the printer output. Also, printing full pages of small print and color will slow things down quite a bit.
hope this helps.
Jul 31, 2010 | HP DeskJet 5550 InkJet Printer
my canon mp830 when printing picks up two or three pages, printing only on the top page. this happens on and off.
try using a better quality paper designed for printers rather than photocopy types. Also it is recommended to "FAN" paper like playing cards before placing into tray. Do this to both top and bottom of paper **** to reduce static in paper which causes it to stick and pull in more than 1 page Frrrrp Frrrrp
please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
161 people viewed this tip
k24674
jasbo
jasbo
