Tip & How-To about Dryers
The motor is running, but the drum isn't spinning.problem with dryer.
Nine times out of ten it's a broken belt, but there are other factors that can cause this problem.
  • Broken belt -- Replace with an identical belt. Line up the new belt with the markings on the drum from the old one. Wind it around both the motor pulley and the idler pulley.
  • Roller could be bad -- Underneath the tumbler is a roller that the tumbler sits on. It may have become too worn to work properly and may need replacing. Replacing it is simple - just remove the tumbler to gain access and then remove the retaining clip on the roller and slide it off. Reverse the process to install a new one.
  • Motor or idler pulley could be bad -- Check the pulleys to ensure they're still in working order.
Dryers Logo
Heater control knob not working
If you can pull the knob off the heat and look inside to see if the knob is broken out. if not you may have a broken switch.
Jun 23, 2017 | Volvo 940 Cars & Trucks
lexus rx 300 does not start
One of a multiple solutions .Gotta have fuel /Gotta have fire.If you have both possoble broken timing belt..With a broken belt sound of engine turning over than be different than normal..Some say like a sewing machine due to no compression. Check fire at a spark plug..If you have fire have someone tap the bottom of the fuel tank with mallet while turning over..Nine times out of ten vehicle will start if fuel pump bad.May start again but not for long...Good Luck
Dec 16, 2010 | 2002 Lexus RX 300
DRYER GETS HOT BUT DOESNT TURN
hello, check inside of the door to see if the long pin has snaped if ok then the capacitor next to the motor may be faulty good luck
regards
shaun
Oct 25, 2010 | Dryers
timing belt alignment marks to replace broken belt.
broken belts on these engine can cause engine damage...the are 2 belts on the ohc engine,
align the timing mark on the bell housing with the centre of the 3 marks on flywheel ( no numbers etc) the others are ign timing marks..each camshaft sprocket has a mark on it and on the cover above it make sure these align also.
Nov 05, 2009 | Subaru GL Cars & Trucks
328 people viewed this tip
Top Dryers Experts
