Tip & How-To about Dryers
Problem with dryer.The drum spins, but there is no heat.
This could be the effect of a number of problems. Here's a list of things to check and details on how to do it.
  • Fuse could be bad -- Check the fuse for a break inside. If it's bad, replace it with an identical fuse.
  • Temperature switch could be bad -- Use VOM to check the switch. Set VOM to RX1, remove leads and touch the probes to the switch's terminals. The reading should be zero or infinity. Turn the switch, and the reading should change from zero to infinity or infinity to zero. If not, the switch is bad.
  • Thermostat could be bad -- Set the VOM to RX1, take a lead off one of the two outside terminals and press the probes to the two outside terminals. There should be a reading of zero. If not, it's bad.
  • Heating coils may be bad -- Set the VOM to RX1 and remove the leads from the coil. Press the probes to the terminals. If the reading is zero, the coil is bad.
  • Timer could be bad -- Disconnect the leads from the motor. Set the VOM to RX100. Clip the probes onto the leads. If the reading is infinity, the timer motor is bad.
Dryers Logo
dryer spins but no heat
Read more: http://www.doityourself.com/stry/repairdryer#ixzz2jQxE03Py
Oct 30, 2013 | Dryers
hi my beko tumble dryer wont heat up i have changed the pc board and the heating element what else could it be thanks
Oct 09, 2013 | Beko Tumble Dryer Heater/Thermostat...
gas dryer starts to heat drum turns then heat shut off and drum keeps running
Sep 19, 2013 | Lands Phones
Dryer will not dry clothes properly
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Feb 10, 2009 | Frigidaire FEQ332E Electric Dryer
Whirlpool Gold Dryer
You will need a volt Volt-Ohm (VOM) reader to fix this problem.
This doesn't rquire sound technical knowledge for this but you should be good at following some instructions.
  • Fuse could be bad -- Check the fuse for a break inside. If it’s bad, replace it with an identical fuse.
Oct 29, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
288 people viewed this tip
Top Dryers Experts
