Tip & How-To about Refrigerators
Tips of Repairing your Refrigerator
For prevent highrepair bill and the expense of replacing all your lost food. This article willprovide some useful tips that how to manually repair your refrigerator andfreezer yourself. Let's star with some basic information.
What you have to Do-
- Always maintain temperature range between 36 degrees Fahrenheit for the fridge, and between 0 to 5 degrees for the freezer.
- Keep clear and clean the coils with a vacuum or duster every 6 months to maintain efficiency and for reduce operating cost.
- During a power outage fridge will stay cold for about 7 to 8 hour and freezer can stay cold about 50 hour. Do not open door unnecessary.
- Daily defrost your manual defrost freezer and do not chip away the frost.
- Full filled fridge is more efficient than a half empty, but do not overfill.
- While moving and storage keep your refrigerator upright.
- After moving the refrigerator wait 24 hours before plugging it in.
- Keep at least 2 inches or air space behind your refrigerator and 6 inches above it.
What you have not to Do-
  • Overfill would not cool as well, so don't overfill your refrigerator.
  • Do not chip away the frost in manual defrost freezer.
  • Do not store your refrigerator unplugged for extended time. Some units or refrigerator require continuous use to ensure proper lubrication of compressor. If possible, plug in it once in a month and keep it run for a couple hours.
By using these tips you willkeep your refrigerator well.
Refrigerators Logo
ice forming
  • One cause of this is the compressor is going bad or Freon is low. The freezer is no longer able to achieve the zero temperature requiring the compressor to run continually. The refrigerator because of the continues running begins to freeze up. Food in the refrigerator begins to freeze and the freezer is not as cold as it should. This results in a very expensive repair of replacement of the unit .
  • The defrost cycle is not working. Depending on the conditions the unit has a sensor that detects when the defrost cycle should initiate. If this fails to occur than ice builds up on the coils and air can no longer pass preventing the normal cooling process. Many models use a mechanical timer that stops. On some units the defrost cycle can be initiated via advancing the mechanical timer. This repair is a reasonable expense.
  • The third possibility is a door was left open and the unit iced up the cooling coils. Suggest in that case shut off the unit , remove the food and allow the unit to manually defrost, Restart and see if unit gets cold and defrost cycle is working.
Nov 22, 2015 | Refrigerators
food remains cold but excessive moisture (condensation) build up
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 23, 2011 | Kenmore Refrigerators
how to kil hydra
Things You'll Need:
  • Aquarium vacuum
  • Additional freshwater
  • Fish food
  • Commercial medication (optional)
  • Step 1:Vacuum the aquarium. Sweep the bottom of the tank with the vacuum to remove the hydra and a majority of their food sources. Use the aquarium vacuum as needed to keep the freshwater aquarium clean. This will prevent more hydra from appearing in your aquarium.
  • Step 2:Replace any lost water. Vacuuming the aquarium will pull out a fair amount of water. Replenish the aquarium with additional freshwater. Northern State University suggests using freshly collected pond water or rain water.
  • Step 3:Reduce the amount of food you feed the fish in the tank. Temporarily decreasing the amount of food will result in larger fish feeding on the hydra and eliminating a source of food for the hydra. If food is unavailable, hydra reproduction will cease and they will eventually shrink then die.
  • Step 4:Repeat these steps as necessary. Continue the three-step process until all signs of hydra are gone. Negligence in cleaning the tank or feeding the fish ample amounts will allow the hydra to feed as well, and thus rapidly reproduce. Continuing the steps is also a maintenance measure that will prevent additional hydra from developing in your freshwater aquarium.
Tips & Warnings
  • Aquarium-supply stores sell various medications that reportedly kill hydra.
  • The steps you take to kill freshwater hydra could also kill small fish in your tank. Prepare to lose some small freshwater fish fry in the process.
Sep 22, 2011 | Computers & Internet
MIcrowave doesn't heat up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fdyjhd
Jul 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
3 Flashing Red Lights - The Fix!
people dont wanna spend money to fix their xbox they want to fix it for free!
Aug 06, 2008 | Microsoft Xbox 360 Console
731 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
