Tip & How-To about Computers & Internet
Providing Care to your computer
If you are using computer there are many reasons why you should take care of your computer, and you would probably like to keep running as long as possible.
Hardware & Software and other are several things you do to have a longer life of your PC. There is always a good thing to clean your computer. A clean hardware will run faster and last longer.
Here are some options for cleaning and maintenance of the operating system on your Computer.
1. Disk Defragmenter run at least once a month. Select this by using this Windows path (Start >all Program>Accessories>System Tools>Disk Defragmenter). The defragmenter will help ensure your Disk files are in the proper place on the computer and will improve the overall speed of your browser.
2. Clean up old files. Disk Cleanup will help you to remove unnecessary files from temporary folder and system folder which are remain after install/uninstall software frequently. Select this by using this Windows path (Start >all Program>Accessories>System Tools >Disk Cleanup).
3. Scan for viruses. Viruses are also may cause your computer to slowdown and not work in proper way. You should always install a good antivirus and keep it update.
Here are some ways you can easily keep your hardware.
1. Each time a while, you should open it and clean it out. Computers are notorious for accumulating dust. For cleaning dust you can use a vacuum cleaner or a can of dust remover can be done.
2. Keep your PC cool. You should always make sure that your computer will keep in a ventilated area. This will help prevent life of your hardware to be extended.
3. Always purchase high-quality hardware.
By following some tips you can be sure you computer to reduce future.
Computers & Internet Logo
my computer keep restating randomly
If you are using Win XP,Win 7 the most obvious problem is that there is a system crash taking place, go toDesktop and then My Computer ->Right Click on it and select properties->Advanced System Setting->IN the System and Recovery click the Settings button->Then in the resultant dialog box if in System Failure section Automatically restart is check then uncheck it the next time it will not automatically restart but show you the reason of restarting, and depending on that you can sort out the problem, most probable reason may be Failure or Unstable Driver's or probably Hardware fault like overheating of CPU etc, or a failing component
Hope it helps !
Jan 05, 2013 | HP Compaq nc6400 Notebook
computer keeps shutting off every five minutes or so
Computer may be shutting od due to following reasons:
Computer Virus
There are higher chances of a computer shutting down due to the interference of a computer virus. The virus gets into the computer and fiddles with crucial sections of the operating system, which may cause the system to shut down automatically. You need to install a good antivirus software and get the computer scanned thoroughly for any malware and viruses. Also see to it that the operating system and all hardware drivers are updated.
Power Supply
The computer power supply unit is an equipment that is installed in the cabinet to provide power to the system for operation. Your computer can shut down, if there is not enough power supplied to it for handling the programs running. If you are using the computer for running intensive software such as PC games, the system would require more power than what is actually available. Another reason can be overheating of the power supply. After the power supply is used for a substantial period of time, there is a possibility of dust getting collected inside it. And this may cause it to overheat, resulting in the shutdown of the desktop computer. If the power supply is at fault, you may need to get a new one installed.
Overheating of the Motherboard and the Processor
As with the case of dust getting collected in the power supply, the computer motherboard and the processor can also collect dust, which may be the reason for their overheating. This may also be one of the reasons why your computer keeps shutting down and restarting. You need to open the computer cabinet and clean the dust off the computer parts. The CPU board and the processor can also overheat because of many applications running. If this is the case, then it is suggested to keep the running of applications as less as possible or increase the size of Random Access Memory (RAM). Bad capacitors on the motherboard is also one of the reasons, why your computer keeps shutting down very often.
The 'Automatically Restart' Setting
If you are using Windows XP operating system, there is a setting that indicates the computer to reboot if it detects an error in the system's operation. In order to check if this is the problem, click on 'Start' and 'Control Panel', then select 'Performance and Maintenance'. Click on 'System', then the 'Advanced' option, and select 'Settings' from the 'Startup and Recovery' section. You will find an 'Automatically restart' option, which you need to uncheck for preventing the system from rebooting. Read more on computer keeps restarting on its own.
These were the possible reasons, why your computer keeps shutting down and rebooting. You also need to check if the power cables are properly connected to the cabinet and to the UPS, as loose connections can also be a reason for system shutdown. The most common cause of the computer getting shut down or restarted is due to overheating of the power supply and other internal computer parts.
Dec 29, 2010 | Mirus Computers & Internet
my computer monitor keeps shutting off randomly for no reason. It isn't the sleep function, I've already checked that and it happens when you are in the middle of using the system. I am running XP
The monitor shuts off or the video card shuts off?
If it's the video card it's probably a heat or driver issue.
If it's the monitor it's probably a heat or ROM issue.
Mar 18, 2010 | Computers & Internet
Anybody, please help! I need it! Sonicwall issues
There are many reasons for your problem, make sure you have the Computer and Register PC are in the switch section of the Sonicwall - not in the WAN port. The router should allow traffic to flow by default. Check the Operating system and turn off any firewalls, the router will take care of that.
May 03, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
check trans light comes on after a few blocks of driving
Go buy the repair manual for vehicle (about 20 bucks) AND a code reader.(between 50 and 300 bucks. Both specific to your vehicle AND vehicle year. Million reasons for check engine light - but that light is basically saying, "I'm seeing something wrong, so check my vehicle computer for what I'm seeing" and the fact that it goes away or may go away just says the problem may be intermittent or keeps being cleared for some reason, either the problem fixes itself or the computer clears code for some reason, probably the former.
Jan 19, 2009 | 1995 Isuzu Rodeo
201 people viewed this tip
David Payne
David Payne
