Tip & How-To about Computers & Internet
How to Clean Your Keyboard
For Desktop Computer:-
The dust that accumulates in a work environment will get inside your keyboard. While this usually does not create a problem for your keyboard, it is a good idea that you clean it out from time to time. Here's how:
1. Disconnect the keyboard from your computer CPU.
2. Turn the keyboard upside down and over a trash can and gently shake the keyboard to remove dirt from between the keys. It is ok to give the keyboard a few slaps on its back side to jar loose any foreign material inside. Also, you can give it a few short blasts of compressed air to help remove debris.
3. You can moisten a soft cloth with a gentle cleaning agent to clean between the keys if you like.
4. Reconnect the dry keyboard.
For Laptop Computer:-
Laptop's keyboards are designed to last a very long time and as long as you don't spill liquid in to it, it should give you many years of worry free operation. You can clean the keyboard by using a very mild cleaner applied to a soft cloth or by cotton. Don't spray the cleaning agent directly on to the keyboard. Gently run the cloth or swab between the keys until clean.
Computers & Internet Logo
my computer hangs/stop responding expectedly and when i check the processor , it very hot , !!! help me plz ...!!!
You can try to disasseble your desktop and check if the processor fan is not working properly. Try to clean accumulated dust and replace it if needed. Also add more fans to decrease temperature inside the system. Do not operate your desktop as possible, it may do further damage to other components of the system.
Hope this helps.
Aug 28, 2011 | Dell OptiPlex GX270 PC Desktop
My HP Slimline Desktop s3120n turns on and as soon as goes on it turns itself off.
it seems your computer needs cleaning and servicing, my advice is to open your pc and use dust cleaner,you can buy a can from any computer outlet, spray all the dust out also all fans,the heat sink on the CPU,make sure also the fan that is connected via the CPU,I believe dust has accumulated between the fan and the CPU,by this the cpu cannot read the from the hard drive all because of so many dust that has accumulate between the cpu, it hard to read the data from hard drive and CPU.
hope this work for you.
Jan 20, 2010 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
sounds like the fan is making a whirring sound for first few minutes after boot up
You should visually inspect the fan (inside and outside the case) to check for dust clogging things up. Very often dust will accumulate on the fans and cause them to slow down, make funny noises, or it will collect on the processor heat sink and cause the computer to run hotter than normal, indirectly causing the fans to work harder to cool the system. If there's no visible dust accumulation, try downloading the newest BIOS for your machine from Dell's support website. A BIOS update may fix the problem by addressing the thermal sensor on the motherboard. Or... you might have a failing fan or thermal sensor.
Jan 14, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Every time i start the pc there is a thermal error message the sound of three beeps then shut down unless pc is left off 48 hours error message.
Thermal event are serious, (too hot) make certain of your fan/fans are working. Clean out the dust that has accumulated. Use you computer in a cool environment if possible. If the error continues, purchase some Arctic 5 ceramic paste take off your heat sync apply a very thin coat to the bottom of the heat sync (after you clean it of course) replace the heat sync.
Also pull out the ram (memory) and reseat it.
This should take care of it. If not please ask again.
Please leave a rating...
May 15, 2009 | Dell Dimension 3000 PC Desktop
Sudden rebooting after 15 minutes of use
several things can be the cause:
Be careful when opening pc with power cord plugged in.
Dangerous voltage which can cause death or severe injuries exists inside pc. If you are not
familiar with handling electricity thye save way DO NOT OPEN THE PC!
1. Is the desktop free standing or in a cabinet or closet? (Overheating?)
1. check for accumulated dust inside the pc. (REMOVE POWER PLUG BEFORE OPENING)
2. check if all fans work.
3. reseat memory chips/cpu and plugs (REMOVE POWER PLUG BEFORE OPENING, ANTI STATIC MESURES MUST BE TAKEN TO PREVENT DAMAGE TO COMPONENTS)
Let me know...
Greetings, Matt
Nov 08, 2008 | Acer Aspire (AST180-US340B) PC Desktop
183 people viewed this tip
David Payne
David Payne
