Tip & How-To about Computers & Internet
How to protect your data and laptop
Laptop is a very sensitive device. So you should be maintain it with proper care.
Some safety tips for laptop-
Cable-
One of the safety equipment is cheaper and more efficient one laptop cable. It is like a lock that you use for the bike. This cable will connect to the laptop and allow it to attach any kind of stationary object. This type of cable is it's much harder to steal for someone, the laptop.
Tactical Software-
If you are looking for such software to protect your laptop, do a little research on the Internet can help you. There are also some sites in the network, providing the test versions of the software.
Sensors and alarm systems-
While the function of Alarm system will be the same, you can see some changes in the mechanisms and specialized. There are some alarm systems in the market today, the buffering sound when someone tries your laptop from the bag will create lift.
Setting of BIOS password-
There many laptops offer protection only by the user through the creation of the boot password. Normally, most users ask three times to enter the password, and to boot, if the application will not refuse to play three times.
Create password for Login-
If the user wants to use the laptop, he or she has to this login ID and password. In the case where the login is wrong, refuses the operating system to allow entry.
Biometric readers-
Biometric reader is also one of the best security options for laptop computers. These type of device you and your machine to determine the assistance people. However, with this security feature on the laptops offera verification hardware level, which in principle requires authentication to boot the system.
Computers & Internet Logo
how to remove the keyboard
Keyboards become worn out over time. Individual keys can become damaged, become less sensitive to key strokes, or disengage from the keyboard. Keyboards can also become corroded from spills. Many keyboards on HP laptops can be replaced. Hewlett-Packard has made hundreds of different laptop models. Each model may require slightly different steps for replacing the keyboard. To locate a replacement keyboard, you can contact HP directly or another online or offline source that sells computer parts.
1.Power off the laptop. Flip the laptop over to access the device's underside.
2.Remove the battery cover and take out the battery.
3.Remove a screw to the left of the memory bay. This screw will be one of two resting in the middle of the underside of the device. You want to remove the right screw, the left screw is attached to the CD/DVD-ROM drive, not the keyboard. (This screw may be red in color.)
4.Flip the laptop back over and raise the laptop screen so you have access to the keyboard area. Insert the tip of a Flathead screwdriver along the bezel and detach it. Carefully pull the bezel up and set it aside. The bezel is connected to the device with a ribbon cable. Do not remove this ribbon cable. (The bezel is the above the laptop and is the cover that houses the power button.) Once the bezel is up, notice the three screws that are beneath it.
5.Unscrew the three screws holding down the keyboard.
6.Lift the keyboard forward toward the mouse area. Be careful, it is still connected to the motherboard by a keyboard cable.
7.Release the cable from the keyboard. Push both ZIF connectors on the side of the cable upwards, toward the laptop screen. Pull the cable from the connector and the keyboard is now released.
8.Insert the keyboard cable of the new keyboard into the ZIF connector. A pair of tweezers may be required to put the cable in place. Lay the keyboard flat down and rescrew in the screws. Replace the bezel cover. Flip the keyboard over and replace the screw on the underside near the memory bay. Insert the battery and battery cover.
Sep 19, 2011 | HP ProBook 4710s Notebook
battery problem
It's quite possible that the battery was not replaced correctly. Many of them are quite sensitive to proper replacement. Remove it again and carefully inspect the metal contact areas on the battery and inside the laptop to determine if any got moved out of place or damaged. Check your Manual for correct insertion of the battery and carefully put it back in as indicated in the manual. It Must completely click into place and be aligned properly so all of the contacts meet. The edges of the battery should be smooth along the laptop case and fit as one.
Jun 11, 2009 | Toshiba Satellite A300-0CF035 Notebook
My acer laptop`screen is not working properly.
ur LCD is broken u have to find a replacement lcd from ebay or google it use a hard cover for the notebook and prevent from unusual hard impacts its a sensitive device take care
Feb 20, 2009 | Acer Aspire 5500 5570-2609 Laptop
Safety Problem
Always protect your eyes - wear only an approved eye or face shield
Aug 27, 2008 | Dewalt DW824 5" Electric Angle Grinder
160 people viewed this tip
David Payne
David Payne
