Tip & How-To about Computers & Internet
Some important tips to update your computer drivers
Computer drivers are useful for your computer run smoothly with some hardware such as hard drive, CD/DVD drive, Graphics Card, USB and other components of your computer.
So it is important to update your drivers when you have a computer. These are tips that how to update your drivers, it will help you to find the problems in your computer when you run some applications. It is important to ensure that they work perfectly with your computer.
If you facing some problems with a device, it may cause of need a driver update. If you have other software on your computer, you may need to update drivers, for it's running smoothly.
Here are some tips that will help you to update these drivers.
The first thing is to know about your driver, there are different drivers on your computer. If we have knowledge of what we need and which hardware required drivers to update, it helps you to find what is to be updated.
The driver for your computer, such as scanner, DVD, printers, video, audio, USB, webcam, digital camera, and others can also your Windows drivers, if you run on the operating system.
You should make your equipment familiar. And do not take too much to go into the depth details of them, but having working knowledge can make your easy. Here are some product online and find it that will takes to be a smooth process.
Everything you need to do is available in start menu click on window update button.
The manufacturer's site will help you to get the drivers for your PC update. You must ensure that you at the exact same model of the device that you looking for update.
If you do not want to search driver updates online and during the test, then you can go to software that automatically update all the drivers on your computer and keep its equipment running smoothly. This process may be the easy and simplest way to update your drivers quickly.
By using these operations your Computer will give you best performance.
Computers & Internet Logo
no power to mouse or keyboard or vga evrery thind elselpowers up fine
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
Click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you hould see driver details and have options to,update driver,roll back driver,uninstall
if your computer came with a motherboard disc the drivers could be on it
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
May 06, 2011 | Computers & Internet
I want to install win7premium32-bit to my pc
It requires at least 2 gb ram and c2 duo or higher. Be sure you have that min with your pc. next you need windows cd. insert it int drive and press F3 or any key to boot with cd. It's then very simple just do as pc says. In format using type choose NTFS next just proceed as directed and you are done.
Dec 14, 2010 | Computers & Internet
D3D Drivers with Hardware Acceleration
Hi. I am getting an error "No D3D Drivers with Hardware Acceleration Found" when i start the Project IGI game. How to resolve this ?
Feb 10, 2010 | Targus USB 2.0 DVD/CD-ROM SLIM EXTERNA DVD...
my brother just gave me his hp pavilion dv4-1313dx laptop and i want to reinstall windows vista. how do i remove windows xp? i just want to clean all of his garbage out of my laptop then reinstall vista, you know make really my new laptop.
First check the System requirements The following list describes the recommended minimum hardware requirements for basic functionality of the different editions of Windows Vista. Actual hardware requirements vary, depending on system configuration and on the programs and the features that you install. If you install Windows Vista over a network, additional hard disk space may be required.
Windows Vista Home Basic
  • 800-megahertz (MHz) 32-bit (x86) processor or 800-MHz 64-bit (x64) processor
  • 512 megabytes (MB) of system memory
    Note On system configurations that use system memory as graphics memory, at least 448 MB of system memory must be available to the operating system after some memory is allocated for graphics.
  • DirectX 9-class graphics card
  • 32 MB of graphics memory
  • 20-gigabyte (GB) hard disk that has 15 GB of free hard disk space
  • Internal or external DVD drive
  • Internet access capability
  • Audio output capability
Windows Vista Home Premium, Windows Vista Business, Windows Vista Enterprise, and Windows Vista Ultimate
  • 1-gigahertz (GHz) 32-bit (x86) processor or 1-GHz 64-bit (x64) processor
  • 1 GB of system memory
  • Windows Aero-capable graphics card
    Note This includes a DirectX 9-class graphics card that supports the following:
    • A WDDM driver
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • 128 MB of graphics memory (minimum)
  • 40-GB hard disk that has 15 GB of free hard disk space (the 15GB of free space provides room for temporary file storage during the install or upgrade.)
Note A Windows Aero-capable graphics card is a graphics card that meets the following requirements:
  • Supports a Windows Display Driver Model (WDDM) driver
  • Has a DirectX 9-class graphics processor unit (GPU) that supports Pixel Shader 2.0
  • Supports 32 bits per pixel
  • Passes the Windows Aero acceptance test in the Windows Driver Kit (WDK
If your computer is compatible follow directions below.
Option 1
loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
OR
Option 2
Note for the option below The computer must be configured to start from the DVD drive.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Please rate this a fixya
May 18, 2009 | HP Pavilion Notebook
194 people viewed this tip
David Payne
David Payne
