Tip & How-To about Computers & Internet
How to transport your computer from one place to another
Most of the people usually save the original containers for items like home electronics and computers, and if you also these containers then it nice method of transporting the equipment. If you have not save it, most moving companies make containers especially for packing, and you can buy containers for packing and protection. And you should have some non-static packing material such as traditional bubble wrap, peanuts and other packing supplies tend to create static.
These are some useful tips for especial items or things.
Securing your Data- this is very important to backup all existing data, either by burning it to CDs or DVDs or in other drives. Most of computers provide their users with a set method for backing up all of the data files. This important because using this method you ensure against permanent loss during the move.
Before packing disconnect all cables - you should remove all cables from main part of the computer. But be care when removing cables, you should remember the cable port and labeled it. After appropriately labeling the cables it is a good idea to store them together in a large plastic bag.
You should empty the equipment - before packing you ensure that all computer drives should be empty. And all ports should have media cards or other items removed before packing. Printer or other items that use toner and ink cartridges must be removed before packing and preparing for transport.
Final loading of computer - for finally moving the computer you can hire any moving companies to transport the computer. And you should prefer transport computer in a car rather than in van.
By using these tips you can move your computer safe.
Computers & Internet Logo
was considering buying a laptop off eBay but the person took the 80gig out and put in a 30gig and it's acting erratic ... I'm just gonna pass on this one ... thank you for you're advice though =)
You can always open a case directly with eBay for items not received or not matching their original description:
http://pages.ebay.com/help/buy/item-not-received.html
Otherwise, if you don't want to deal with all of that, just upgrade the hard drive yourself : ) And if that's beyond your expertise, you may be able to buy a replacement hard drive and take it somewhere (Best Buy or a local computer shop?) and have someone replace it for you.
Mar 02, 2011 | Computers & Internet
What does “unboxed” mean?
Unboxed items are genuine, authentic, fresh and 100% original. Sometimes the outer box gets damaged in transit so it is removed. Unboxed items always contain the same original fragrance as the boxed versions. They are the best way to save. Boxes can become damaged while shipped or handled, or the bottles can be scratched so we can purchase them for less and pass the savings on to you.
If the UPC codes or any other tracing codes are missing, altered or defaced from any product box or bottle, it was not done by the manufacturer and occurred in the supply chain after it left the manufacturer.
Nov 23, 2010 | Health & Beauty
diablo 2 cheats to get a powerful armor and items
these are the only cheats, not really cheats, but its worth it:
  • Windowed game Start the game with the "-w" command line parameter to run it in a window on the desktop.
  • Cow level Successfully complete the game to get the Horadaric Cube. Then, obtain "Wert's Leg" in Tristram (where you go to rescue Deckhard Cain). Go to the northwest part of the town and search the boy's body. Place both Wert's leg and a Tome of Town Portal in the Horadaric Cube, and it will open a portal to a hidden level filled with axe carrying cows. Do not go through the portal until you are over level 35 because the cows are quite numerous and strong.
  • Imbue without worry When you get an item and want to imbue and are worried about the outcome, copy the "Save" folder from the Diablo 2 folder to the desktop or any other location. Start your game and imbue. If you do not like what happened, save the game and exit. You will now be at the main menu again. Press [Alt] + [Tab] and copy the save folder back to its original location. Then click "Single Player Game" and start. You have another chance to imbue the item. Repeat this until you get the desired effect.
  • Retrieve items after death Save and exit the game after dying. Restart the game, and your corpse will be in town, allowing you to retrieve your possessions.
  • Avoid no-win situation Press [Esc] when facing imminent death, then save and exit the game. Load the game again to start in town, where you can buy weapons, life, etc.
  • Gain money and items quickly Travel past the Blood Moor and look for a cave. The cave has two levels, with a golden chest somewhere at the second level. Inside are usually health potions, mana potions, scrolls of town portal or identify, unidentified weapons and armor, and sometimes even a rare item that can be sold for a great deal of money. If you identify the item and it is something that you do not want, sell it. Save and exit the game. The next time the game is loaded, the chest will still be there with different items. This can be done as many times as needed.
  • More money for items Identify or repair items before selling them.
  • Infinite one way portal Cast a Town Portal from a safe location, then take the portal into town. Use the waypoint system and run to get back to your last location. This allows you to use the portal to go back into town an unlimited number of times as long as you do not use it from town to return to where you were previously.
  • Duplicate items Note: This trick only works in an Open Battlenet game, as the characters need to be saved on your computer. This trick also requires two computers with two copies of Diablo 2. Get the items to be duplicated. Copy the "Save" folder from the Diablo 2 folder of that computer and paste it on your desktop. Go online with both computers and meet in a game. Give the items to be duplicated to the second computer, then save and exit. Press [Alt] + Tab] on the first computer to switch to Windows and copy the "Save" folder from your desktop back to its original location, overwriting its current contents. Return and join the other computer in the game. You will now have all your original items and the other computer will have a copy of them. Note: This does not work with the +1 Skill book from Act 2, as you are only allowed to do it once.
    Note: This trick also only works in an Open Battlenet game. Take the item to be duplicated and place it in your inventory. Then, save and exit the game. Next, come back to the game or join a different one. Drop the item you want to duplicate. Make a note of the game name and password, then sign off of your ISP -- do not save and quit the game. Have another person in the game keep it open while you are logged off. Sign back on to your ISP, go back into the game, and pick the item that you dropped. It will also still be in your inventory, so you now have two copies of that item.
  • May 26, 2010 | Computers & Internet
    Still getting "Projection lamp is nearing end of life"
    KDF46E2000 - Change Lamp Warning - Reset
    Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
    Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
    1. TV must be in standby mode. (Power off).
    2. Press the following buttons on the Remote Commander within a
    second of each other:
    DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
    contains the Category with the Adjustment Item you want to change.
    2. To change the Category, press 2 or 5 on the Remote Commander.
    Note: Pressing 2 or 5 only changes the categories within the
    Service Menu displayed. To change a Category on one of the other
    Service Menus, press the JUMP button until the correct Service
    Menu is displayed.
    3. To change the Adjustment Item, press 1 or 4 on the Remote
    Commander.
    4. To change the Data Value, press 3 or 6 on the Remote
    Commander.
    Note: To go back to the last saved Data Value, press 0 then ENT
    on the Remote Commander to read the memory.
    5. To save the changes, press MUTING then ENT to write into
    memory.
    6. To exit service mode, turn the power off by pressing POWER .
    Wait 2 minutes before restarting the set to allow the fans to
    completely shut down or the Service Menu will appear on the screen.
    easyab
    ConvergenceRepair.com
    __________________
    Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
    136 people viewed this tip
    David Payne
    David Payne
