Tip & How-To about Computers & Internet
How can add Horizontal Lines in Document Quickly with Word 2007?
With this technique we can add horizontal lines without having to use of the ribbon on the top of the page. It is very easy to add horizontal line in Word 2007 just using the keyboard shortcuts. You will be able to insert many different designs by using the keyboard.
You can use one of the following methods.
1. For adding a simple straight line, type three dashes (---) and press Enter.
2. If you want to add the style of a horizontal line, type three asterisks (***) then press Enter.
3. You may type three underscores (___) and press Enter for got this line.
4. For getting this line type three equal signs (===) and press Enter.
By using these shortcuts you can break two paragraphs in Word 2007, you may to break the numerous sections of a document.
This is the simply way for using a new character like asterisk, equal, underscores, or dashes, you can add style to the Word document.
Computers & Internet Logo
I have a Panasonic TC-P50G10 television that now has numerous small horizontal black lines. Can you advise?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 11, 2016 | Panasonic TC-P50G10 Plasma TV
How to get lines on horizontal lines on the page.
you have to turn on the border. Highlight cells that you want to add the lines to, Right click on the highlighted cells, and select "Format Cells" Then choose the boarder tab. To only do horizontal lines, simply click on the top and bottom lines. This will turn the borders on, and then they will print.
Aug 12, 2014 | Microsoft Excel 2010
tally 6100 missing lines
horizontal or vertical characters missing???
if your missing horizontal lines, look at where the print is missing if you see imprints... u have bad ribbons.
if your missing vertical characters down the page
Power off the printer & unplug from wall
Remove with phillips the top right cover. u will see that the control panel has a plastic clip needs to be pressed in for the control panel to come loose from the top right cover.
Then you will see P703 Hammerbank Ribbon Cable and
P704 Hammerbank Ribbon Cable swap these 2 cables on the Engine Controller Board part# 083368.
IF your missing characters move to another place on the printout then u will need to replace part# 083368.
IF your missing characters are still in the same place, then you will need to replace hammer module part# 081152, their is qty 11 of the individual 081152 about 1 inch wide. this will save $$$ ordering and replace 081152 if you have some at your work semi technical.
Be very careful with hands when powering the printer with the top right cover off
Electrically and mechanically.
Need more help you may call Toby at x311
Apr 24, 2009 | Tally Line Matrix T6100 Printer
579 people viewed this tip
David Payne
David Payne
