Tip & How-To about Computers & Internet
How to connect Bluetooth with your laptop and cell phone?
When your laptop or desktop computer isnot supporting it, then we can use a USB Bluetooth dongle. By just plug it intothe USB port. You may leave the rest to Microsoft Window. MS Window will findthe driver and install it itself.
If by this process it is not supporting,then we can install it manually with using the manufacturer's CD.
By using these steps in order toBluetooth technology for connect laptop and cell phone.
Turn on the Bluetooth option on your cellphone.
Go to option (my Phone's visibility ->Shown to all on the cell phone)
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);By clicking on Device Manager you can find Bluetooth driver.
Then click on the Add button appear in Bluetooth Devices dialogbox.
Click on the Next option.
Then the device wizard willappear and it will display the name of the found Bluetooth device close by.
Click on the name of devicewhich you would like to add and click on Next button.
Select option "Let me choose myown key" or select "Choose a passkey for me" then click on Next.
Then the passkey will appear. Key thisinto the cell phone. Now the laptop is initiating to install the Bluetoothdevice package. Select Yes button as you see the prompt message on the cellphone to allow your connection with the laptop.
Now click on Finish button forclose the dialog box of Add Bluetooth Device Wizard.
Bluetooth of cell phone device is now willdisplay in Bluetooth Devices dialog box. Select that Bluetooth device and clickon the Properties button.
Properties of the dialog box forthe device will be visible. Select the Service tab.
Now check the boxes for theservices which you want.
Finally you can launch the items of the cell phone. Now you can Transfer photos, videos, images etc to cell phone via this Bluetooth technology.
Computers & Internet Logo
usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
What is Bluetooth Dongle?
Hi message4,
Welcome to FixYa! How are you doing?
Bluetooth Dongle is often refer to USB Bluetooth Adapter, it is a device which you connect to your computer via USB port to allow data transfer from your PC or Laptop to Car Kits, Mobile Phones, PDAs, GPS Receivers and much more.
Hope that helps. Thank you for using FixYa.
May 01, 2011 | Acer Aspireā„¢ T180 PC Desktop
add a mouse
Yes.
Most wireless mice come with a small wireless USB dongle that you plug into a USB port.
If your laptop supports bluetooth, you can get a bluetooth mouse, and you wont need to plug anything into your USB port.
Have a look at the logitech nano mouse.
May 24, 2009 | eMachines E620-5885 Notebook PC
i have purchased a bluetooth usb dongle and cannot see where to plug it into my aspire sa80 computor
Hello there.
I have found a picture of the back of your computer. Please see below. The picture is a little small im sorry.
A bluetooth dongle connects over the USB port in your computer, while you have some slots in the back you should have some in the front as well. They look like this:
Hope this helps.
May 28, 2008 | Computers & Internet
244 people viewed this tip
David Payne
David Payne
