Tip & How-To about Computers & Internet
Tips to secure your computer from overheatingTips to secure your computer from overheating
There are some simple ways that make you aware about your problem regarding computer overheating.
1. The Cabinet fan and processor fan inside the system keeps the computer cool and free from dust. So keep these fans working on.
2. Always keep your computer clean inside for stop a computer from overheating.
3. For stop your computer from overheating always put it to sleep mode when it's not going to be in use.
4. If you are using a laptop, you can prevent it from overheating by purchasing a cooling pad, and do not put it on a restricting surface like your pillow or bed.
5. Always try to put your computer in cool place from preventing from overheating.
These steps will prevent your computer from overheating successfully.
Computers & Internet Logo
COMPUTER SHUTS OFF
There are several reasons for Auto shutdown of the PC, it can shutdown due to CPU processor overheating, Hardware conflict, SMPS voltage supply issue. what ever may be the reason, if you have knowledge of assembling then you can try below steps
1. Open the cpu cabinet and remove the heatsink then clean it.
2. clean the CPU Fan (use some spray like WD40)
3. Remove the old heat sink paste from the processor and apply heatsink paste and refix all the hardware.
4. check the voltage supply of the SMPS (power supply unit)
otherwise you can call computer hardware engineer and get the problem fixed.
Apr 18, 2014 | ASUS M11AA-US002S Multimedia Desktop PC
my gx620 thermal fan overheats
A) FOLLOWING Anti-Static Procedures;
1) Clean the inside of the computer out
2) Replace the Thermal Paste on the Processor (CPU)
THOROUGHLY clean top of CPU (Processor), and bottom of Heatsink.
PROPERLY apply fresh, new Thermal Paste.
http://www.hardwaresecrets.com/article/274
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
http://www.dell.com/support/Manuals/us/en/19/Product/optiplex-gx620
Click on the blue ->
Dell Optiplex GX620 System User's Guide (5990KB)
Using Mini Tower Computer as an example;
In the list click on;
1) Removing the Computer Cover
2) Processor
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 13, 2013 | Dell OptiPlex GX620 PC Desktop
THERMAL OVERHEATING SHUTDOWN
1) Clean the inside of the computer. Power unplugged to computer, Anti-Static Precautions used, use a can of air, or two, to clean.
(Compressed air for computers)
2) Computer case open, computer plugged into power, turn the computer on, observe the cooling fans.
A) Processor: A processor may have it's fan sitting on top of the finned Heatsink, which sits on top of the processor,
OR, the fan may be a computer case fan in the Front of the computer, and uses a plastic tuned port to deliver air from the fan to the Processor.
In either case observe the rotation of the fan. See if it seems to be spinning at the correct speed. (RPM's)
See if it spins intermittently. Spins a few times, then slows down, or stops, and then spins again.
3) Check the Thermal Paste.
If the thermal paste in-between the top of the Processor's case, and the bottom of the Heatsink, has dried up, the Processor will overheat.
If a Thermal Pad is used, remove it, fly it at the cat like a Frisbee. They are J-u-n-k.
Clean the top of the Processor's case, and the bottom of the Heatsink, THOROUGHLY, and Properly apply fresh, new thermal paste.
For additional questions post in a Comment.
Regards,
joecoolvette
Dec 09, 2011 | E-Machines eMachines Desktop PC
turning off in 2 minutes automatically
My guess is that the fans inside the computer have stopped working, thus leading to the overheating. AMD processors generally run "hot" (50 to 60 degrees Celsius) even with proper fans.
Take your computer to a qualified technician, for a cleaning, and proper trouble-shooting, and repair, before the overheating causes permanent damage.
Jul 27, 2010 | HP Compaq Presario 2100US Notebook
DEAR SIR, I AM USING INTEL 945GNT DESKTOP
shutdown is due to overheating there is a sensor inside every processor to protect it from overheating nd if the temperature goes above this temperature it automatically shutdown.
if you are using a desktop then change your cabinet buy a airy one with extra fan installed in it. or you can open one side of your cabinet to sink the heat quick;y.
Apr 06, 2010 | Intel Computers & Internet
198 people viewed this tip
David Payne
David Payne
