Tip & How-To about Televison & Video
How to make Program for making an Universal Remote Control
For making a universal remote control it takes few steps by using the Automatic Code Search method.
First: Turn on the component that you want to make the program for universal remote control.
Second: Now press the component button on your remote that corresponds to the component you want to the remote to operate such as TV, VCR, etc. The illuminated on-off button will turn on and keep on.
Third: Press both component and on-off buttons. The illuminated on-off button will turn off, and then will come back on.
Forth: Now release both buttons after the pressing on-off button turns back on. The button must remain illuminated.
Fifth: Then press and release the "play" button. If the component does not work wait few seconds, than continue to press the "play" button every five seconds until the component turns off.
Sixth: Finally press and release the "reverse" button when the component turns off, and then wait to see if the component turns on again.
Seven: Press and release the "STOP" button to save the new code of your remote control.
Now it is your new remote control that will work on your all component as universal remote control.
Televison & Video Logo
i have a oleia tv im trying to program my rca rcu403 but it wont work
your oleia tv code is 1610 OR 1240 OR 073
In order for the 3 component universal remote to control your TV you must program it with the TV code
that matches your TV These instructions explain the preferred method of programming the remote the
Direct Entry method 1 Manually turn on the TV
2 Locate the enclosed TV Code List. Find your brand of TV
Note If your brand isn t listed, use one of the Code Search methods to
program this remote control See Code Search on page 24
3 Press and hold the CODE SEARCH key until the indicator light
illuminates Then release the CODE SEARCH key
4 Press and release the TV key The indicator light blinks and then remains lit
5 Use the number keys to enter the first code listed for your brand.
After you enter a valid three digit code, the indicator light turns off
Note If you enter an invalid code the LED will flash rapidly for 2 seconds
Start over at step 3
6 Aim the remote at your TV and press the ON OFF key If your TV turns off
you have found the correct code
7 Enter the code in the box provided on this page for future reference.
8 If your TV doesn turn off repeat steps 3 6 above entering the next code
for your brand.
If none of the codes work or your brand is not listed use one of the Code
Search methods to program this remote See Code Search on page 24
For a description of each key on the remote control refer to the Key
Descriptions section
If your component s brand isn t listed in the Code List or you have tried all of the codes for your brand and
the remote does not operate your component use one of the Code Search methods below Manual Code
Search or Auto Code Search. Both Code Search methods search all of the codes because your component s
code may be listed under another brand in the code list.
Note The Code Search method may take a long time because the remote searches all of the codes in its
memory for the code which operates your component. Therefore, if your brand is listed in the Code List
use the Direct Entry method described Manual Code Search
1 Turn on the component you want the remote to operate.
2 Press and hold the CODE SEARCH key until the indicator
light illuminates. Then release the CODE SEARCH key.
3 Press and release the component key that corresponds to the
component you want the remote to operate TV
indicator light blinks once and then
remains lit
4 Aim the remote at the component and press the ON OFF key
continuously until the component turns off
Important Because there are so many codes, you may have
to press the ON OFF key many times possibly up to
200 times.
5 When the component turns off press the ENTER key to store
the code
6 Use Code Retrieval on the next page to identify the code for
your component for future reference
Nov 05, 2011 | RCA RCU403 Remote Control
I need to know how to program a RCA universal remote RCU404N
Hello
Programming method for your remote control follows:-
In order for the 4 component universal remote to control your DVD player or auxiliary component, you must program it with the code that matches your component. The DVD•AUX key can be programmed to operate a DVD player or a second TV, VCR, DBS or cable box. These instructions explain the preferred method of programming the remote-the Direct Entry method.
1. Manually turn on the component you wish to assign to the DVD•AUX key (TV, VCR, DVD, DBS System or cable box).
2. Locate the enclosed DVD code list, or the
corresponding code list for the auxiliary component (TV, VCR, DBS, or cable box).
Note: If your brand isn't listed, use one of the Code Search methods to program this remote control (See Code Search on page 9).
3. Press and hold the CODE SEARCH key until the INDICATOR LIGHT illuminates, then release the CODE SEARCH key.
4. Press and release the DVD•AUX key. The INDICATOR LIGHT will blink.
5. To program for DVD, press the VCR key. For an auxiliary component, press the corresponding component key (TV, VCR, DBS•CABLE). The INDICATOR LIGHT will blink again, then remain lit.
6. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off.
Note: If you enter an invalid code, the LED will flash rapidly for 2 seconds. Start over at step 3.
7. Aim the remote at your component and press the ON•OFF key. If your component turns off, you have found the correct code.
8. Enter the code in the box provided on this page for future reference.
9. If your component doesn't turn off, repeat steps 3-7 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote (See Code Search on page 9).
Mar 18, 2011 | RCA Televison & Video
RCU410wms RCA Remote
http://remotefinder.rca.com/default.aspx?site=rca
This site will give you the codes;
Enter the codes 1> Press Hold Code Search until light stays on
2> press device button ie.TV
3>enter 3 digit code from site
4>Try Power button, if works great if not try another code
That's It!
Feb 10, 2008 | RCA Universal Remote Control
programming my universal remote
Hi, It takes just a few steps to program an RCA Universal Remote Control using the Automatic Code Search method. While there may be some trial and error, the pleasure of getting rid of several extra remote controls will far outweigh the hassle in getting it programmed. Instructions Steps 1. Turn on the component you want to program. 2. TwoPress and release the component button on your remote that corresponds to the component (TV, VCR, etc.) you want the remote to operate. The illuminated ON-OFF button will turn on and remain on. 3. ThreePress both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on. 4. FourRelease both buttons after the ON-OFF button turns back on. The button should remain illuminated. 5. FivePress and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off. 6. SixPress and release the REVERSE button when the component turns off, then wait to see if the component turns on again. 7. SevenPress and release the STOP button to save the new code. more help http://157.254.235.130/public/RCR430.pdf all the best sreejith
Jul 16, 2007 | RCA RCR460 Remote Control
498 people viewed this tip
Top Televison & Video Experts
