Tip & How-To about Computers & Internet
How can test Laptop?s temperature and temperature should it be at?
If your laptop is not working ideally it may be the cause of temperature. But most laptops naturally run hot, so a system utility that can access your laptop's internal temperature sensors can help you decide if you need to take some steps to keep your laptop cool down.
Most CPU's maximum temperatures are around 100 degree Celsius. But you can look up temperature specifications for your specific laptop's Intel or AMD processor. Optimal operating temperature is 50 degree Celsius or below.
Some programs will help you to test your Laptop's CPU Temperature that can show you the CPU temperature as well as other system details such as processor load, voltage, and more. And some of them can also automatically adjust the speed of your laptop's fan for better performance.
Speed Fan- In the case of monitoring fan speeds, voltage, and processor temperatures using your laptop's internal sensors, Speed Fan can also access S.M.A.R.T. information to set your hard disk's temperatures.
Real Temp- The real temp is specially designed to monitor temperature for all Intel single, dual, and core processors. In the case to showing the temperature and load the processor, it also shows the CPU's safe maximum operating temperature and how far from this maximum temperature your processor is running at. Another most important feature of Real Temp is tracking of your highest and lowest temperatures since you opened the program.
These tips may help you to determine the exact temperature for your laptop.
Computers & Internet Logo
it dont work on lenovo
There are many reasons y0our laptop is running slow.
1. Make sure the ventilation holes of the laptop are not blocked with dirt, or blocked by placing laptop on your lap, or a non-hard surface. When the CPU gets hot, it will throttle down to run slower. You can install a temperature monitoring program to determine if the CPU is running too hot. 2. If the temperature is within normal range, then check to see the amount of free space on your HDD. Keep at least 10% or more free. 3. If that is ok, then you may not have enough ram to run all the programs. Windows 7, or 8 should have at least 4GB or more RAM. 4. If that is ok too, then you may have a lot of unnecessary programs running. Run a virus scanner program to get rid of viruses, etc. 5. Uninstall unused programs. Sort by date to see which programs were installed most recently, By doing this if you can remember when you started having problems, you can uninstall programs installed around that time that may be causing your problems. As you can see a lot of things can cause slowness. Good luck!
Mar 31, 2015 | Lenovo IdeaPad Computers & Internet
How do I stop my S3520 computer from shuting down automaticaly when unattended
Is it only shutting down when unattended ? Which operating sytem ?
if your laptop keeps shutting off
If your laptop suddenly shuts itself off for no apparent reason, there are several factors that can contribute to the problem.
When you troubleshoot the laptop, remember that it is also possible for a combination of causes to be at work.
Excessive Heat
Keep Cool
All newer laptops have built-in heat sensors that shut the computer off when it exceeds a pre-set temperature threshold. Install and run a temperature monitoring utility to determine whether the laptop is overheating.
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Hardware Issues
If you replaced or installed new hardware in your laptop, use the device management utility to review if there are any resource conflict or failure reports. You can also remove unnecessary hardware and run the laptop to see if the problem persists. If it doesn't, reinstall each hardware component and re-test until the laptop fails.
Operating System Issues
The operating system start-up controls can affect how the laptop performs.
Follow the operating system developer's instructions for entering the start-up program, and confirm that the settings are what your laptop requires.
Power Supply
If the laptop computer suddenly shuts down, it could be because of a break in the power supply.
If the laptop is plugged into an outlet for power, check to see if the plug was pulled from the socket and make sure the cord is properly connected to the computer.
If the laptop is running on battery power, then it is possible that the battery is drained and no longer has enough power to run the computer.
A simple recharge of the laptop battery should fix the problem.
Typically, a laptop has an indicator on the screen that tells how much battery life is left so that a shutdown is not a surprise.
Failing batteries can produce unexpected laptop shutdowns.
Use a battery monitoring utility to determine whether or not the battery is healthy and replace it if it isn't.
Malware
Unfortunately, rootkits and viruses can cause your laptop to shut down without warning.
You will probably have to take the hard drive out of the laptop to be able to scan it fully and remove any malware that is installed, or the laptop will shut down before the scan and repair can finish.
http://www.malwarebytes.org/mbam.php
Malwarebytes is as the name says, a Malware Remover!
Download the Free Version from the link above.
Download, install, update and scan once a fortnight.
http://www.spybot.info/en/index.html
Spybot Search & Destroy 1.6.2 is a very good, FREE Anti-Spyware Program.
Download, install and update it.
Then SCAN with it.
Update it, and scan your System once a fortnight.
Hope this helps
Dec 04, 2012 | Computers & Internet
my lenovo G460 shuts down unexpectedly
http://ct.download.com/clicks?t=1141982088-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5
avg free 2012
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
If you believe a virus may be the cause of your laptop's shutdown problem, run a virus scan on the system to find out if any exist.
Excessive Heat
Keep Cool
Hardware Issues
Power Supply
If your laptop is not getting the correct power it requires, it will shut down completely. Test the current of any outlets you use with your computer, employ a surge protector to ensure steady current, and confirm that the power supply itself is not defective.
Battery
Malware
Then SCAN with it.
Hope this helps
Oct 29, 2012 | Lenovo G460 Laptop Computer - 06777TU...
Sometimes when I start my laptop (usually when my USB broadband device is connected), the screen will start flickering and the laptop will make a whining noise for about a minute or so before shutting down. I'm thinking it's either from the fan not running anymore or perhaps the motherboard is going bad. I have a USB fan I put underneath the laptop when I am using it to help with the heat build-up.
Indeed your problem seems to be a temperature problem, especially if this happens after a working period and the laptop gets hot. Let's start with the easy solution:
Shut down your laptop and remove the battery. Use a soft brush (and if possible air under pressure) to clean up pedantically the air blinds all around the laptop. In case of using air under pressure leave the laptop to "rest" (and the temperatures and humidity to balance) for about 15 minutes. Check for your problem again after this.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Oct 05, 2011 | HP Compaq Evo n610c Notebook
ideal classic LXFF not igniting but still giving
ch themistor may be faulty,or divertor not working.
these are the two things that may cause this
Dec 31, 2009 | Jason Natural Cosmetics Jason Forma...
417 people viewed this tip
David Payne
David Payne
