Tip & How-To about Computers & Internet
How to repair hard drive
Instructions Things You'll Need:
  • Operating software installation or build CD
  • Boot-up disc
  • System restore CD
  • Backup tape
  1. Look for tell-tale signs that your computer is about to crash or fail. Extreme slowness, repeated blue screen and noise or clicking are sometimes signs that your computer hard drive is about to crash. When you hear the sound of clicking, scraping or grinding, immediately turn off or shut down your computer. Doing so will prevent any loss of data.
  2. Power down and then power up. Sometimes, hard drive crashes can be easily recovered by doing a power shutdown of the computer. Then, after waiting for a couple of minutes, power it back up again. The initial hard drive crash may not be too serious, but if it happens often, start performing a full system backup, if you haven't been doing so, to be able to recover your data should the inevitable happen.
  3. jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/8f/3a/repair-hard-drive-crashes-1.3-800X800.jpg'); }); PC cable or component connection Ensure that your hard drive and other internal components are seated properly. If Steps 1 and 2 do not work, you may need to open your computer's CPU to check on some of the drive connections. Sometimes connections get dislodged, especially if you move your computer box often. The symptom will manifest as if the hard drive has crashed, giving you a "disk error" when you try to boot up your computer. First, turn off your computer and unplug it. Then remove the case of your computer box. Press on each connector to connect it properly. Put the cover back again, plug the computer and power it back up.
  4. jQuery(document).ready(function(){ jQuery('#jsArticleStep4 span.image a:first').attr('href','http://i.ehow.com/images/a04/8f/3a/repair-hard-drive-crashes-1.4-800X800.jpg'); }); Boot from CD drive with a boot disc Insert your boot disc and try to boot up your computer using the disc. Once you are able to do so, you can reinstall your operating system. After installing your software, proceed to perform data recovery using your ghost CD or backup.
  5. Use an emergency repair disc to get your computer to work again. Then restore from the last known good configuration.
  6. Reinstall your operating system using the installation or system restore CD that came with your computer when you first purchased it. It will take you through a series of steps that include formatting your hard drive, which will then erase your data. Do this as a last resort.
  7. Recover your data by using a restore and recovery software or using your most recent backup after you have reinstalled the operating system in the previous step.
  8. Reinstall your applications that did not come with your computer when you bought it. Some examples would be Adobe Photoshop, anti-virus software and movie-making software.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
  • Call technical support if you are unsure of what to do. They can walk you through the important steps. You can also take your computer to a PC technician who, for a fee, will do a system restore and data recovery for you.
  • Make it a habit, even if your computer is healthy, to do a complete backup so your important data will not be lost.
  • Never attempt to open your computer without first powering it off to avoid being electrocuted.
  • Do not open your hard drive case; the components are so sensitive that even a single speck of dust may erase your data.
Computers & Internet Logo
lost my paperwork and disc
You'll need to install the printer driver on your computer. From there, the Lexmark software will give you step-by-step instructions on how to install and setup your printer.
Please visit the Lexmark website to download and install the Lexmark X4690 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
After installing the printer driver, try to print a document to verify that the software is installed successfully.
Jan 04, 2012 | Lexmark X4690 Wireless InkJet Printer
nokia c201 phone update settings
There is no settings for phone updates. Things you'll need is your phone, usb cable, nokia software update installed on your computer. This is a risky task so I won't recommend it. But if you wish to try, make sure you have enough charged battery and and the usb cable/connector is good. You'll also need to connect the phone is PC suite mode not in Mass Storage neither in Picbridge mode. Please follow this LINK and follow the instructions given there.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 12, 2011 | Nokia C201 Cell Phone
i need a free key to reset a laptop purchased at a flee market
Depending on the make/model/os, and various other things, you'll need to reformat/reinstall. There might be a recovery partition you can boot to to reformat to factory settings. Look around on google for your make/model and "recovery partition" to find out how to access it. If there's no recovery partition, you'll need to install your own operating system. Purchase Windows, or download a linux DVD, then put it in your CD drive and boot to the CD (usually you can change boot order in BIOS settings or as it boots. Look for things like "F2 for system settings" as the bios is loading. You can also hit the pause/break key (might need to hold down function) to halt the bios so you can look a little easier). Once it boots to the CD drive, your operating system should start the installer sequence.
Jun 15, 2011 | Computers & Internet
i have to nimbuzz softwer for china mobile sigamantal
Hi there!
You can download the nimbuzz here
http://www.nimbuzz.com/en/mobile/download
Go to the above page
Provide you country, phone number enter captcha and they'll text you the download link
OR
go to
get.nimbuzz.com (from your mobile)
Follow the on-screen instructions on your mobile phone to install Nimbuzz
OR
you can download the nimbuzz.jar from here
http://www.filecrop.com/Nimbuzz-.jar.html
Once you have downloaded the JAR file from the above link copy it your mobile phone and run the software (There'll be no need to install it)
thanks
Jun 09, 2011 | Computers & Internet
I need to know if i can recover the Operating System on my Sony laptop it has a OEM harddrive I lost the Operating System by Mistake can i recover the Operating System Through the BIO"S or dose it need a new one My Operating System is Vista Pre The Model number is VGN NS130E
How did you lose the operating by mistake? Did you format the drive?
You can not recover the operating system from the bios. But you may have a choice when the computer boots up there may be a recovery option, you can try that. If not you would have to reinstall or try a repair from a vista disk if you can borrow one from someone. Please let me know if I can offer any other help, Thanks for using FixYa
May 15, 2011 | Sony VAIO Notebook
173 people viewed this tip
David Payne
David Payne
