Tip & How-To about Computers & Internet
Three simple ways to recover Windows XP password
This may happen when you attempt to log in to your Windows XP and you realize you lost the password. Just because you can't remember or some hackers had change your password.
It's easy to gain access to Windows after losing user account password. Just simply login as the computer administrator and go to control panel->user accounts. There you will be able to reset the password for any of the systems user accounts.
Howerver, things will get more tricky if you have lost Windows administrator password. It's a sickening,powerless feeling to be locked out of your own computer though this happens more often,everytime we feel so helpless.What should you do in facing this situation.You have tried everything you could but failed.
This problem of Windows XP password recovery often troubles most PC users, especially for those who have little computer skills. For this, following are three simple ways on how to recover Widows XP password to help you login your computer again.
Method 1: Login as Safe Mode
Start system and press F8 key when Windows is starting up. Then select Safe Mode with Command Prompt and enter. Choose Administrator,the default password may be blank if you don't set the default administrator password before.Then you will enter into doc Command as following.
Type " net user net user xxx 12345 /add " (xxx is the locked account name and 123456 is the new password set on this account).Then you will see the Command Completed Successfully.
Method 2: Using A password reset disk
Windows XP and further versions also provide another method to recover forgotten password by using ""Reset Disk"". If you created a Password Reset Disk in past, you can use that disk to recover Windows XP password as follows.
Step 1: Start Windows and click your username when you get to the Windows XP logon screen. Type the password wrongly.
Step 2. Press Enter and you will see the error message about "Did you forgot your password?
Computers & Internet Logo
lost my password to presario cq57 have any advice
A Windows password reset disk is always used to reset Windows password if you have created in advance.
Here are the steps to use the disk for your password recovery.
Step 1: If you enter the wrong password when you attempt to log on, Windows will display a message that the password is incorrect. Click "OK" to close the message box.
Step 2: Click "Reset Windows Password", and then insert Windows password reset disk (or other removable media).
Step 3: Follow the steps in the "Password Reset Wizard" to create a new password.
Step 4: Log on with the new password.
More solutions reference: http://www.windowspasswordreset.net/article/article.html
Jul 17, 2012 | HP Computers & Internet
forgot log-on password for my COMPAQ Evo N180
You can reset your password by logging into windows in safe mode,it wont ask for a password
when you do that and once you are into windows you can go and reset or remove your password from
control panel.To know how to get into windows safe mode and reset the password please follow the
instructions from the below link,hope it helped.
http://www.wikihow.com/Log-on-to-Windows-XP-if-You-Forget-Your-Password
Nov 25, 2010 | HP Compaq EVO N180 Notebook
how to reset password on my compaq computer!
Start pc in "Safe Mode With Command Prompt" When windows starts, type your log in name in the dos window with an asterisk. For example ( john * ) but with out the (). It will prompt for a new password. Reboot and Bam your in. If you cant remember a log in name exactly as it is, type in ( net users ) and hit enter.
Jun 13, 2010 | Compaq Digital PC 3100 PC Desktop
dell lattitude c 600
under battery or keyboard you will find cmos battery,remove,than install back.will have to enter date,time etc again.
Jun 26, 2009 | Dell Latitude C600 Notebook
148 people viewed this tip
David Payne
David Payne
