Tip & How-To about Dryers
Have a dryer? looking for wiring diagram
Most dryer manufacturers, put a copy of the wiring diagram, in the control console area. Behind the knobs and lights.
Dryers Logo
I need a wiring diagram for asko dryer
They usually put the wire diagrams inside the actual console area, they make it to where only services can find it. If it isn't inside the console then try going to asko website to see if they have a PDF file you could download
Jan 31, 2014 | Asko T700 Electric Commercial Dryer
we have a whirlpool duet front load dryer, why does it beep during a cycle?? when clothes are still wet?
You can perform some Whirlpool electric dryer timer troubleshooting to determine if the timer is faulty or if the cause is somewhere else within the dryer.
  1. Access the Timer
    • Unplug the Whirlpool dryer power cord from the dryer electrical outlet. The timer is inside the control panel on the top of the dryer. Pull the dryer away from the back wall so that the control console can be raised without hitting the wall.
      Remove the single screw on each end of the control console that secures the control console housing to the top of the dryer. Grab the sides of the control console and raise the front of the console up and toward the rear of the dryer. With the control console in the service position you will now be able to test the timer.
    Test the Timer
    • Locate the dryer timer inside the control console. It will be directly behind the dryer timer control knob. There are two wires that connect from the dryer to the dryer timer. Place a piece of masking tape on each wire and write on the tape what terminal each wire attaches. Use a pair of needle nose pliers to remove the wires from the terminal ends on the timer.
      Set the scale on a volt-ohm meter to the RX1 setting to measure the ohms of the timer. Place one probe to one terminal and the other probe to the remaining terminal. You should get a reading between 2,000 ohms and 3,000 ohms. If you do not get this reading, replace the timer.
    Replacing the Timer
    • Pull the control knob off of the timer shaft on the face of the control console. Remove the two screws that secure the timer to the inside of the control console. Pull the timer out and take the timer with you to an appliance repair facility. Compare the new timer to the old timer to make sure that the mounting screws match.
      Place the new timer inside the console and secure the timer with the two retaining screws. Attach the wires to the timer and remove the masking tape from the wires. Lower the control console and reattach the console to the top of the dryer with the retaining screws. Push the control knob back over the timer shaft. Push the dryer back against the wall and plug the power cord back into the electrical outlet.
May 21, 2011 | Whirlpool Duet Steam WFW9700V Front Load...
Whirlpool dryer model LEQ8858JQ0 - won't turn off by its self, just runs and runs no matter what cycle it is on.
  1. Access the Timer
    Test the Timer
    Replacing the Timer
Apr 18, 2011 | Whirlpool LEQ8000JQ Electric Dryer
wires came unplugged from behind control knob
Below is the link to the wiring diagram to your dryer, it should help some. In addition what I can tell you is that most appliance components have initials next to the connections that indicate what color wire is supposed to be connected to them, this is where the diagram should help. In cases of things like switches, buzzers, thermostats, things that only have to do with circuits being open or closed they will not have an initial so therfor it doesn't matter what wire goes to what connection. Post again if you need more help. http://www.appliance-parts-warehouse.com/frigidaire-parts/Frigidaire-Dryer-Parts/Frigidaire-Parts-GLER331AS2/Frigidaire-Parts-50169.cfm
Jan 22, 2009 | Frigidaire GLER331A Electric Dryer
where can i get a wiring diagram for a kemore elec dryer model 110.86692300?
The model number you provided is for a stacked model washer/dryer combo. If this is correct, look behind the panel directly below the operator console. The manufacturer usually places a wiring diagram behind the panel for service technicians. Post back if it is not there and I will see if I can provide you with a better solution.
Apr 07, 2008 | Dryers
358 people viewed this tip
Top Dryers Experts
