Tip & How-To about Pool & Spa
General Information You Should Know About Your Swimming Pool
WwwWeFixUglyPools.com is one of the largest providers of swimming pool services in the state of Arizona and is expanding quickly throughout the United States.
Lots of questions arise that seem pretty simple to us, but we realize most homeowners are on a learning curve with their pools (especially first time pool owners!)
FYI- Did you know that proper water chemistry is the single most important way to keep your pool from turning green? That's right, with proper water chemistry maintenance, the water of your pool will stay clear even if you can't run your equipment. We have maintained pools for us to *6* MONTHS without running the pump!
FYI- In the high heat of the summer, your pool uses more chlorine than normal due to the intense strength of the Arizona sun. To keep a pool clear, a stabilizer chemical (much like a sunscreen for your pool), must be balanced to keep the sun from burning away all the chlorine.
FYI- Stabilizer is included in small amounts in all chlorine tabs, so a stabilizer build up can happen over time which causes the chlorine to not be able to work effectively. It is best to watch your stabilizer (also known as CYANURIC ACID) and make sure that the levels never get too high!
FYI- If you do not have regular pool maintenance and you want to know what your pool stabilizer level is, simply take a sample of your pool water to any local pool store and ask them to check it for you. If your stabilizer (CYA) levels are too high (stabilizer build up) this will require a change of water*.
*This can be done by draining your pool and refilling it with fresh water, or draining only a portion of the pool and refilling it, or as in the case of summer time heat, backwashing several time a day/week to gradually change out the water
FYI- Too little stabilizer will cause you to use more chlorine to avoid that condition, will require the addition of cyanuric acid.
FYI- DO NOT DRAIN YOUR POOL IF THE TEMPERATURE OUTSIDE IS CONSISTENTLY OVER 80 DEGREES. THIS CAN CAUSE SEVERE DAMAGE TO YOUR PLASTER OR PEBBLE TECH.
For more tips on your pool contact The Ugly Pool Guy at www.WeFixUglyPools.com.
Pool & Spa Logo
Can anybody recommend best pool cleaning service Mesa?
Approximately one million in-ground swimming pools as well as three million above-ground pools are had by property owners in the U.S. These are amazing data that should have focus on pool safety and security suggestions. It is so simple to believe that absolutely nothing bad will ever before take place, but pool-related crashes cause about 50,000 trips to the emergency room every year. Below are some suggestions to keep your swimmers safe.
Never Swim Alone . Get better pool cleaning service here - Pool Service La Mesa
Swimming alone can be very hazardous, even if you are a great swimmer. Many drowning incidents take place when somebody is in a pool alone. Cardiac arrest and injuries can be ruining if they occur in the water as well as, without any one around in order to help, can lead to deaths. Children need to never ever be left alone in a pool for any reason.
Pool Building and also Maintenance
To assist stop injuries, make sure you make use of non-slip products on your deck. Water and also unsafe surfaces are a crash waiting to take place. You could likewise use non-slip materials on your diving board as well as ladders. Pool ladder steps must be 3 inches thick at a minimum. Steps that are as well little can create a misstep too quickly. Additionally make sure to check your pool's devices to make certain that everything is tidy and also running effectively. This would certainly include the pump, filters and also various other equipment.
Pool Usage
Educating your youngsters to swim as early as feasible (generally by the age of 3) will help them be a lot more independent in the water. Certainly, small children ought to never be left alone for any reason, even if they have actually had swimming lessons. To minimize the chance of accidents, prevent pushing people into a pool, obtaining wild around the pool edge, and also various other activities that could result in injury. Never drink alcohol then swim. This is a deadly combination that could result in serious effects.
Taking Additional Precautions
It is very advised that your pool be surrounded by a high fence that can be locked when the pool is not in use. This prevents kids from roaming right into the pool area ignored. It can likewise deter undesirable guests from using your pool as an enjoyable, however prohibited task.
Keep a flotation device in your pool area in all times. Unfortunately, mishaps take place without warning, and also it is best to have one about. When utilizing a pool cover on an above ground pool, take the cover off entirely when the pool remains in usage. A partly opened pool is a hazard.
Knowing fundamental CPR is a great idea for house owners. Classes are conveniently available in numerous cities and also communities around the United States Recertification must be done yearly.
A great deal of the tips for staying risk-free around your pool are common feeling. Normal maintenance of your pool equipment as well as sticking to the guidelines can imply the difference between a relaxing, fun time in the sun, or an unforeseen trip to the emergency clinic. Do your finest to remain secure this swimming season.
Steve Lane is a self-employed writer of informational sites on individual protection as well as home safety items consisting of advanced monitoring. He is just one of the leading authors on residence safety and personal self defense products in the nation.
He began "Self-defense Shop" in 2004 to assist people stop crime in their lives. "Self Defense Shop" is an Internet business specializing in difficult to locate and also one-of-a-kind self-defense as well as residence protection products that help individuals shield themselves, their family, home and business. His site consists of self-defense products like pepper sprays, stun guns, personal alarm systems, and also self-defense training DVDs.
Mar 13, 2017 | Pool & Spa
It tries to fire once and fails. heater service lite then comes on. The LED red lite on the Fenwl Box blinks 3 times indicating ignition lock out. What do we do to fix this problem?
Hot Tub Spa - Heater Troubleshooting Guide - PoolAndSpa ...
www.poolandspa.com/page596.htm
The World's Oldest & Largest Web Site For Swimming Pool & Hot Tub Spa .... close to the element, and the pump suddenly quits - it's dry fire time in just a minute or two. ...We think it's a safe bet to say that one of the major causes of heater failure ... It's much easier to describe what doesn't cause it than to attempt to explain ...
Spa and Pool Heating Problems - Swimming Pool Information
Jan 05, 2016 | Pool & Spa
westcraft. Where can I get a manual and assembly diagram?
[PDF]Operating Instructions and Parts Manual Drill Press
https://www.northerntool.com/.../manuals/12...
Northern Tool + Equipmentour Authorized Service Centers located throughout the United States can give you quick service. ... HOW TO GET SERVICE ..... Exploded View Drawing JDP-15M/MF . ... If you are not familiar with the proper and safe operation of a drill press, ...
www3.nd.edu/.../Jet%20Drill%20Press%20JDP...
University of Notre DameCompletely read the safety and maintenance instructions before operating or servicing the machine. To obtain maximum life and efficiency from your JET Drill Press, and to aid in ... Authorized Repair Stations located throughout the United States can give you quick ...... A spindle speed and pulley/belt arrangement chart.
[PDF]Operating Instructions And Parts Manual 17" Drill P
Dec 18, 2015 | Drills
900 people viewed this tip
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
