Tip & How-To about Televison & Video
Don't place the TV near the thermostat.
The yeat generated by television, as detected by the thermostat can cause the air conditioning unit to run longer than necessary ... and you know how a pig / cs as much power.
Televison & Video Logo
haam air conditioning split then I switch on come to E7 what is the problem in my a c please give me answer any parson
Malfunction of Outdoor Unit Fan Motor ( E7)
Remote Controller
Display
E7 Method of
Malfunction
Detection
Abnormality of fan motor system is detected according to the fan speed detected by hall IC when the
fan motor runs.
Malfunction
Decision
Conditions
?? When the fan runs with speed less than a specified one for 15 seconds or more when the fan motor
running conditions are met
?? When connector detecting fan speed is disconnected
?? When malfunction is generated 4 times, the system shuts down.
Supposed Causes ?? Malfunction of fan motor
?? The harness connector between fan motor and PC board is left in disconnected, or faulty connector
?? Fan does not run due to foreign matters tangled
?? Clearing condition: Operate for 5 minutes (normal)
Troubleshooting
Caution
Be sure to turn off power switch before connect or disconnect connector, or parts damage may be
occurred.
Replace the outdoor unit fan motor.
Connect the connector.
Remove the foreign matter.
YES
NO
Are fan motor
connectors
disconnected?
NO
YES
Is the pulse input?
Check No. 11 Check for pulse input
for number of rotations
on the outdoor unit
PC board.
Replace the outdoor unit PC board.
YES
NO
NO
YES
Is there
any foreign matter
around the fan?
Can the fan be
easily rotated by hand?
(S2584
Jun 07, 2016 | Heating & Cooling
I want to install an air conditioning unit on the roof of a 1995 ford econoline van. How do you do it?
The air conditioners on RVs are 110 volt AC. They do not run on 12 volts and should not be run on inverters. You would need at least a 2000 watt generator, preferably 3000.
If you have the power, it requires cutting a 14 inch square hole in the roof. The air conditioner is clamped down by 4 bolts from the inside, part of the internal control package. You would need what is called a "non-ducted" inside unit which would have the thermostat and control knobs.
Mar 14, 2015 | Heating & Cooling
the RV i'm working on has 2 roof units,both start to cool then comp cuts off , there is 1 thermostat with dual zones,its on a 2006 motor home,it dorsn't seem like both would be bad
Can you get 1 to run good at a time, or does same happen when 1 only is run? Some RV's have an energy management system incorporated, that cuts power back to certain appliances when necessary. There were/are some units (RV's) that needed to be plugged in as well as generator running in order to run 2 AC units at same time. Let me know.
Jun 01, 2010 | Dometic Rooftop RV Air Conditioner
278 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
