Tip & How-To about Computers & Internet
Many of you get your mobile phone wet by one way or another. You worry as you mistakenly drop your mobile phone in water. It can also get wet if you are out in a heavy rain. However, there is no need to panic. It is possible to save your wet mobile phone by quickly repairing it. In order to save your mobile phone from water damage, you can consider these easy and simple solutions:
Act rapidly :
The first thing you have to do in order to save your wet mobile phone is to act rapidly. Quickly remove all the detachable parts as well as covers possible such as the back cover, battery, the SIM card, memory card etc. Next, take a piece of cloth or a tissue paper to wipe the excess water you are able to notice within the mobile phone. Make sure that you dry it completely. If you don' t do this, the water inside the mobile phone will begin to evaporate and gather in places which will be difficult to reach.
This will save your wet mobile phone and it will start working if it was under water for just a little while.
Using a hairdryer :
Take a hairdryer and begin drying the mobile phone while giving more consideration to the place where the battery is located. The battery housing usually consists of tiny holes to let in air (so giving more space for water) inside the mobile phone.
Make sure that you are not holding the hairdryer very near to the mobile phone. Keeping it too close to the mobile phone may harm the electrical mechanism of the mobile phone. Keep on drying the mobile phone from a safe distance for about twenty to thirty minutes.
If solution number 1 and solution number 2 don't work, try solution number 3.
Drying for a long time:
Take off the covers as well as battery from the mobile phone. Put the phone in a dry as well as warm place to let the water inside the phone evaporate gradually from the little holes in the mobile phone.
As the mobile is wet the circuit board inside the mobile
will be fully wet. Due to this the connections between the circuits get
connected (short circuited) and the mobile may behave in such a manner that it
should not behave. NEVER put the wet mobile in charger even though it is dry
and working properly. There may be water logs present in the mobile circuit
which may be dangerous to the person who is using the mobile. It may lead to
electric shock.
Take the mobile to the authorized dealer of your make and
they will remove the water log from the
mobile circuit board and it will be fine .I recommend you not to do this by
yourself.
Thank You
