Tip & How-To about Computers & Internet
HOW TO RUN TRIAL VERSION SOFTWARE ON PC FOREVER
Mere adjustment of PC's date and time at the control panel
does not do the magic as most sites would tell you.......
RunAsDate is a small utility that allows you to run a program in the date and time that you specify. This utility doesn't change the current system date and time of your computer, but it only injects the date/time that you specify into the desired application.
You can run multiple applications simultaneously, each application works with different date and time, while the real date/time of your system continues to run normally.
Using RunAsDate
RunAsDate doesn't require any installation process or additional DLL files. In order to start using it, simply copy the executable file (RunAsDate.exe) to any folder you like, and run it.
In the main window of RunAsDate, select the desired date and time and the application that you want to run. Optionally, you can also specify the command-line parameters to run the program. Press the "Run" button to start the application with the specified date/time
RunAsDate Limitations
RunAsDate only works on 32-bit Windows applications. You cannot use it for old DOS 16-bit programs or for 64-bit Windows applications.
RunAsDate will not affect applications that take the current date/time from another source. For example: application that loads the current date from remote serve
TO DOWNLOAD
visit http://www.nirsoft.net/utils/run_as_date.html
Computers & Internet Logo
safescan ta 850 instuctions
go to control panel and see the icon date and time, enter and adjust the clock. enter the country where you are , example Mexico, etc
However if you have persistent problem measure the small battery from lithium from +3vdc, with VOM, if the voltage is low from 3, replace it. and clean the contact battery. if the battery is o.k , always clean it. all data will be new ,since this battery control the memory RAM.
God bless you
Jul 13, 2013 | Computers & Internet
adjusting date/time windows xp
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab (right click on the time to adjust)
hope this helps
Aug 09, 2012 | Microsoft Windows XP Professional Full...
sony vaio vgn-fs775p laptop real time clock not keeping time
Hi
thank you for your query
If the time is not keeping up then it would seem that you will need to change your CMOS battery, this is a small battery found on the motherboard responsible for clocking etc
The battery is cheap to purchase, however I do highly recommned the laptop be booked into a reputable PC shop for replacement as you will need to take the whole laptop apart to get the motherboard
I hope this has been helpful
Mar 09, 2010 | Sony VAIO VGN-FS790 Notebook
mere pc mea se voice nahi aa rahi........na hi wo volume controler dikha raha hai desktop mea........
do one thing
open control panel then click on the sound speech and audio devices after that click on the adjust system volume a dialog box will appear infront of you then click on the hardware tab there is realtek(whatever your audio software's name) or audio codec click on them then click the properties tab and check whether the device is enabled or not......
Jul 04, 2009 | Computers & Internet
I need to set day and date display on my computer
I assume you mean date/time right click with the mouse on the time at bottom right hand corner a list will appear left click with mouse on adjust date\time a screen will appear and you can adjust time and date on that screen.
Another way to access this control is left click start button highlight control panel double left click with mouse and double left click on date/time option
Apr 27, 2008 | Computers & Internet
258 people viewed this tip
David Payne
David Payne
