Tip & How-To about Computers & Internet
Windows Compatibility Issue for Older Programs
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and then select the Windows version you know the program worked on before. This way the program will be run as it would run under Windows XP or Vista, 32 bit or 64 bit.
You can find more about this Compatibility issue on http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Computers & Internet Logo
New computer running Windows 7. Print Master Platinum will not open. Is there a fix? Ran fine with XP.
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and select the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website.
Jan 06, 2011 | Sierra Print Artist Platinum
I installed printshop 2.0 deluxe on my new computer running windows 7 and I can't get the program to load up. What can I do?
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 24, 2010 | Broderbund The Print Shop Deluxe Version...
will not load into windows 7
Dec 15, 2010 | Mindscape Printmaster Gold Classic 3.0...
My create a card cold is not compatable with my windows 7 computer
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. Do the same for the installer if it wouldn't install. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 13, 2010 | Broderbund American Greetings Creatacard...
Is there a Creatacard CD compatible for Windows 7?
Creatacard cannot be run under Windows 7 because of compatibility issues. You have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 05, 2010 | Broderbund American Greetings Creatacard...
1,447 people viewed this tip
David Payne
David Payne
