Tip & How-To about GPS
Use Your Car's Speakers
Why listen to directions (and MP3s and phone calls) on the speaker tinny little in your GPS? Many high-end GPS receivers are equipped with an FM transmitter to send audio to speakers car stereo. This may work in rural areas where the FM band is not as crowded, but to find a free frequency, will be a challenge in cities.
One possibility is to use the headphone / audio jack, you can also find an average level of GPS units. Connect the cable car stereo aux patch, and the bliss of static-free sound.
GPS Logo
garmin 1300 no sound
no sound ? does it have sound with turn by turn? can you hear sound with a headset plugged in..
try a few of these to resolve ....... on main menu press the Volume Icon... is it Muted, if not on that page do you see FM Trans....press it ....under FM Transmitter is it checked? if so uncheck it only have a checkmark in it if you use your radio station to listen to your gps on your car speakers
now if that is all ok then try..... Tools.... Settings....Language.... under Voice tab select one that ends with ( TTS ) text to speech
Nov 12, 2010 | Garmin nuvi 1300 Car GPS Receiver
Alesis RA-100 amp is tinny
To test speakers get a 1.5 volt battery and put the (-)wire of the speaker to the negative end of the battery. Then take the + wire and for a split second touch the positive terminal of the battery. You should hear the speaker pop! Listen to each unit inside the speaker, any that don't pop are not working.
If you look inside the amp you may see that something has burnt up. Look carefully at whatever is on the heat sink.
Dec 09, 2009 | Audio Players & Recorders
Sound is terrible, except speakerphone
Hi!... You need to replace the ear speaker of your phone and it will be okay.
Oct 01, 2009 | Nokia 2600
Navi660 bluetooth fails to work
if your device is equipped with an FM transmitter feature, you should disable it in order to enable the device external speaker. and to check that go to volume>FM trans>diable
Sep 25, 2009 | Garmin nuvi 265 Car GPS Receiver
332 people viewed this tip
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
