Tip & How-To about Cycling
10 Tips to Avoid Looking Like a Cycling Rookie:Tip 1: No Pro Kits Tip 2: Buy the coolest helmet you can afford Tip 3: Buy cycling clothes that fit Tip 4: Shave the legs Tip 5: Avoid "rookie marks" Tip 6: Pick the right accessories Tip 7: Dump the reflectors and "plastic ring" Tip 8: Practice with your clipless pedalsTip 9: Unless you're riding a mountain bike, no hydration systems! Tip 10: Know the cycling etiquette
Cycling Logo
2017 Bajaj Pulsar 150 how to get better fuel economy
Hi, Anonymous the following tips are low cost easy to apply/install and guaranteed to give you better gas mileage and a smoother running bike. The average motorcycle gets 56-64 KMPL. saving .2 Litre of gas could save you a 10 Kilometer walk. 125cc scooters have been known to get 185 KMPL.and more.
1. Proper tire inflation as per MFG. specifications wheels should be balanced and spokes tight.
2. Oil and coolant levels maintained at full marks, low levels produce excessive heat that causes the engine to work harder and reduces efficiency.
3. Keep extra weight to a minimum.
4. Take off from a dead stop should be smooth and easy throttle applied avoid excessive throttle snaps.
5. Smaller windshields get better KMPH than large ones, wind resistance increases as a square of the speed at which you're traveling. For example, at 112 KMPH, wind resistance is double what it is at 80 KMPH (70 squared is almost twice as much as 50 squared). That will dramatically reduce your mileage. Keep that in mind while biking.
6. Keep idle time to a bare minimum or turn off the engine.
7. Re-jet carburetor with a smaller main and mid-range jet.
8. Keep chain/belt properly adjusted.
9. Avoid quick braking, hasty acceleration, high-speed driving, try driving the speed limit and keep a constant speed.
10. On long trips use freeways or flat straight stretches of highways rather than city or rural routes avoid hills and mountains when possible.
11. Keep your engine clean, dirt and grease/oil hold in heat.
12. A full-face helmet is more aerodynamic than other types of helmets. Any other clothing that decreases your aerodynamic should be reconsidered.
13. Any unnecessary bling on your bike is going to decrease fuel efficiency.
14. Use high-quality fuel using low-quality fuel can cause sludge in your fuel injectors.
15. Keep warm up time to a minimum get off the choke ASAP.
16. Motorcycles run best when their engines are maintained, and that includes making sure the air filter is clean, the spark plugs are fresh, the fuel filter is free, and the timing/valves are adjusted.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the links below. Good luck and have a wonderful day.
Tips on How to Increase Bike Mileage
Bike Mileage Tips 10 Quick Tips to Improve Your Bike Mileage https://www.cartrade.com/answers/17319.html
Bajaj Pulsar 180 DTSi Workshop Manual
Bajaj Bike Spare Parts
Bajaj Pulsar 150 DTS User Manual
Jan 23, 2018 | 2011 Bajaj Pulsar 150
Which workout songs would help me to do cycling faster?
You can prefer to listen to these popular cycling Exercise Music that would help you do cycling faster:
a. Cycling Summer GH 2016
b. Cycling This Is How We Roll By Darcia
c. Cycling Mo Bounce by Elizabeth
d. Cycling Party Up by Elizabeth
e. Cycling Back to Skool 2017
f. Cycling Billboard Awards 2017
g. Cycling Bee Gees Saturday Night Fever
h. Cycling Wild Thoughts
Aug 24, 2017 | Exercise & Fitness
I have pulsar 150 , how to increase its fuel mileage ?
Hi, Tushar the following tips are low cost easy to apply/install and guaranteed to give you better gas mileage and a smoother running bike. The average motorcycle gets 35-40 MPG. saving .2 gallon of gas could save you a 6-mile walk. 125cc scooters have been known to get 115 plus MPG
5. Smaller windshields get better MPH than large ones, wind resistance increases as a square of the speed at which you're travelling. For example, at 70 mph, wind resistance is double what it is at 50 mph (70 squared is almost twice as much as 50 squared). That will dramatically reduce your mileage. Keep that in mind while biking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
10 best tips to get maximum mileage for bikes VIDEO
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarOwner%20Manual.pdf
Jun 17, 2016 | Motorcycles
My passion 2006 have aengine new but average is low pl. Suggest mr
Hi Anonymous for carburetor issues the usual suspects are:
1. Excessive choke use.
2. High-speed riding style.
3. Idle speed improperly adjusted.
4. Dirty air cleaner element (may also affect idle speed).
5. Vacuum piston assembly malfunction.
6. Excessive accelerator pump output.
7. Plugged or restricted bowl vent.
8. Fuel level too high.
9. Loose jets.
10. Worn or damaged needle or needle jet.
11. Enrichner valves not seated or leaking.
12. Plugged air jets or passages.
The following tips are low cost easy to apply/install and guaranteed to give you better gas mileage and a smoother running bike. The average motorcycle gets 35-40 MPG. saving .2 gallon of gas could save you a 6-mile walk. 125cc scooters have been known to get 115 plus MPG
5. Smaller windshields get better MPH than large ones, wind resistance increases as a square of the speed at which you're traveling. So, for example, at 70 mph, wind resistance is double what it is at 50 mph (70 squared is almost twice as much as 50 squared). That will dramatically reduce your mileage. Keep that in mind while biking.
For more information about your issue please click on the links below. Good luck and have a nice day.
hero honda passion plus pdf 1 Docs Engine com
http://www.toprelated.com/catalog/hero-honda-passion-pro-wiring-diagram.pdf
Hero Honda Passion Plus 2006 service manual DOWNLOAD FREE FULLMANUALS COM
http://www.partsfish.com/page/oem-parts-for-honda
May 10, 2016 | Motorcycles
570 people viewed this tip
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
