Tip & How-To about Cycling
Proper Bike Storage Tip
Proper Bike Storage.The best place to store a bike is inside. Shelter will protect it from thieves and the weather. Left outside, a good bike can rust and corrode to dangerous condition in less than a year. This is especially true if you live near the ocean where salt in the air is super corrosive. If your apartment is small, simply install a bike hook and hang your bike from a wheel. These hooks are cheap (about $3 at hardware and department stores) and they'll screw into any wood wall or stud in a plaster/sheetrock wall. Be creative: maybe you can hang your bike in a stairwell or a closet; above your bed (cool!) or in the kitchen? You can find a spot if you look a bit. Take it from a guy who once stored six bikes in plain view in a 900-square-foot apartment (to my wife's dismay).
Cycling Logo
JUST BOUGHT A 2004 DT125R IT HASNT BEEN STARTED FROM 2006 BIKE WAS LEFT UNDER A COVER OUTSIDE BITS OF SURFACE RUST THAT BOUT IT STEERING LOCK CEASED IS THIS BIKE STILL ANY GOOD
Surface rust will come off without leaving weak framework. The engine will, if not rotted out, refurbish so as a rule, it is probably worth rescuing.
A Yamaha DT125R hopeful owner will be pleased to own it. The engine may be OK after lubrication and a little TLC.
Jan 27, 2011 | 2004 Yamaha DT 125 R
battery problem
Tip: Check the fluid levels on each chamber. If any chamber is low, carefully top it up. Use only distilled or deionized water, NOT tap water. Tap water has minerals in it that will not do the battery any good.
The humble battery is a very common cause for motorcycle breakdowns! Unfortunately they are awkward to get to and therefore do not get checked as often as they should.
A battery only requires a little monthly maintenance to perform perfectly. Keep the battery charged to 100%, recharging when the lights dim, the starter sounds weak, or the battery hasn't been used in more than two weeks. Other than that, follow this simple check list every month:
- Check the electrolyte level
- Top up only with distilled or deionized water, wear gloves and protective glasses. Top up in a well ventilated area, Beware of fumes.
- Keep the top free of grime
- Check cables, clamps, and case for obvious damage or loose connections
- Clean terminals and connectors as necessary
- Check inside for excessive sediment, sulfation or mossing
- Make sure the exhaust tube is free of kinks and clogs
- Replace caps firmly
- Finish up by testing the battery with either a hydrometer or voltmeter. To extend the service life of your battery, make monthly battery maintenance part of your routine.
Storage can be hard on batteries. In fact, non-use can leave them unable to hold a charge.
Store your bike in a place that is always warmer than 32 degrees. If your bike is outside remove the battery from your bike and store it in a location that is always warmer than 32 degrees. This will insure that your battery does not freeze and crack.
If you remove the battery from your bike DO NOT store it on a concrete or metal surface, place the battery on a wood or other non-conductive surface. Batteries stored on concrete or metal will discharge over time.
Place a charger on your battery. Trickle charge your battery at least once a month. A battery that is fully charged will have a longer life and is less likely to freeze during cold winter weather.
May 17, 2009 | 1990 kawasaki ZXR 750
Winter storage
I am not the original guru, but when storing a bike for a long period you should:
- Fill the fuel tank as much as possible to prevent rust forming inside the tank.
- Best to rest the tyres on something soft (bit of carpet maybe) to stop them going hard on the concrete.
- Disconnect the battery (possibly store that inside the house or shed) and a few days before you wish to ride again put the battery on trickle charge.
- Cover the bike with a waterproof cover to keep the moisture off of it best you can.
Dec 18, 2008 | 2006 Yamaha SR 400
Winter storage solution for a 2008 Yamaha Royal Star Tour Deluxe
you can take out the plugs - inject a little engine oil, crank the engine 5-6 times and reinstall, support the bike so the weight is off the tires, drain the gas and spray the tank with a rust preventative....
Nov 18, 2008 | 2008 Yamaha Royal Star Tour Deluxe
271 people viewed this tip
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
