Tip & How-To about Computers & Internet
How to Optimize Windows 7 for better performance with Registry Cleaner Software
Windows registry is a hierarchical database used to store information, containing Windows continually references during operation, such as profiles for each user, the applications installed on the computer and the types of documents that each can create, property sheet settings for folders and application icons, what hardware exists on the system, and the ports that are being used, that is necessary to configure the system for one or more users, applications and hardware devices. The longer time a computer works, the more errors will be caused by installation of software. If faulty operations accumulate in the computer system, your PC will work very slowly, and when the situation goes worse, instability halt and even breakdown could occur to the system.
Windows 7 comes as a significant performance improvement over its predecessor, Windows Vista. But if you want to get the very best performance possible, you should make a few system tweaks to eliminate resource-hogging programs and features. No matter how fast or shiny computers might be when they're new, they all seem to get slower over time. Many people hope to fix the registry manually, but here I remind you that if you are not a specialist who posses a good knowledge on computer, you will have to take the risk caused by modification in person. As the reasons above, a good registry cleaner is really necessary to solve registry errors and optimize your PC. Here, Clever Optimizer will be your best choice to help you speed up Windows and make your PC work better-even without upgrading your hardware.
Clever Optimizer is the most powerful software for cleaning the registry errors. It is used to repair common errors in the computer and eliminate various errors caused by software installation and false operation, normally these errors include slow speed, crash or freezing, blue screen, error messages etc. With the most advanced technology, it also can locate the errors in registry and system by scanning every part of system and then diagnosing them comprehensively and scientifically in a short time. Meanwhile, it provides the most professional and effective functions as follow to solve the problems and tries to make the performance of your computer perfect.
1.Registry Optimizer
It provides a quick, comprehensive and customized scan over your system and eliminates some common computer problems such as low speed, blue screen, system halt and breakdown caused by the errors in registry.
2.Junk File Cleaner
There are many junk files created after the system running for a long time. It can help you remove all unnecessary trash files in the system to make your PC work faster and more effectively.
3.Windows Optimizer
This contains Startup Manager, System Optimizer, Application Optimizer and Internet Optimizer. It can optimize system parameters to let Windows run faster and boost your system performance.
4.File Shredder
It will shred or destroy unuseful files after recovery and completely removes a file folder or drives information from your computer, then makes it impossible to restore these files and information again.
With other more functions, Clever Optimizer can absolutely help you optimize your PC and maintain the integrity of your Windows registry by cleaning junk files and safely repairing registry errors. So with [b]Clever Optimizer[/b] in your PC, you will have a high processing speed system. Please free download it from official website: http://www.cleveroptimizer.com/download.html.
Next, some tips for you to how to Optimize Windows 7 for better performance with Clever Optimizer:
1.Clean up windows registry and junk files
http://www.cleveroptimizer.com/forum/Snap1.jpg
With high-performance detection algorithm, Registry Cleaner will identify and repair missing and invalid references in your Windows registry after full and quick scan. Your PC will be twice-born and absolutely run much faster than before. Then scan and clean up the junk files from your system to free valuable storage on your hard drives and allow applications to run faster and more efficiently.
2.Limit programs run at startup
http://www.cleveroptimizer.com/forum/Snap2.jpg
Startup Manager allows you easily administer which programs are automatically launched at the system startup. That is, you can stop the unneeded programs that could run at the system startup to improve system-boot speed.
3.Optimize Windows system and applications
http://www.cleveroptimizer.com/forum/Snap3.jpg
Windows optimizers can clear all useless files that may make your PC down and unstable. It will automatically optimize your system with the pre-settings of the optimizer model. Your PC will run faster and more efficiently with its ability of cleaning and optimizing your PC.
4.Repair bad ActiveX and IE
Clever Optimizer repair tool is the most comprehensive Windows Repair Tools in the Market for optimizing your system, cleaning and repairing Windows registry, fixing PC crashes and error messages, restoring IE default settings to keep browser secure and faster. Besides those above, it can repair or block malicious ActiveX to improve system security and repair broken file association to avoid future system crashing.
With Clever Optimizer,you could also delete the records of chatting, cookies of website and programs used in the computer to protect the security of personal information. Moreover, it will be easy to remove the items form BHO list to get high-speed internet explorer run. In addition, it provides registry backup and favorites backup, which greatly streamlines your surfing enjoyment, perform a full backup of your system files, registry, favorite websites, drivers at any time you wish. If you encounter a system problem, these backup tools make it easier for you to keep your data safe from user error, hardware failure, and other problems. Of course, you can get more information you want to know about Clever Optimizer from http://www.cleveroptimizer.com/
It's believed that Clever Optimizer must fascinate you after your better understanding. Now, please scan your computer with it and you will enjoy better performance Windows 7 soon by following the tips above. In addition, you'd better scan your computer every week to keep your Windows registry free from errors and keep your computer running smoothly.
Computers & Internet Logo
vhjytry
The Windows Registry is a hierarchical database that stores configuration settings and options on Microsoft windows operating systems. It contains settings for low-level operating system components as well as the applications running on the platform: the kernel, device drivers, services, SAM, user interface and third party applications all make use of the Registry. The registry also provides a means to access counters for profiling system performance.
Sep 29, 2009 | Computers & Internet
regestry editor
A central hierarchical database used in Microsoft Windows 98, Windows CE, Windows NT, and Windows 2000 used to store information that is necessary to configure the system for one or more users, applications and hardware devices.
The Registry contains information that Windows continually references during operation, such as profiles for each user, the applications installed on the computer and the types of documents that each can create, property sheet settings for folders and application icons, what hardware exists on the system, and the ports that are being used.
The Registry replaces most of the text-based .ini files that are used in Windows 3.x and MS-DOS configuration files, such as the Autoexec.bat and Config.sys. Although the Registry is common to several Windows operating systems, there are some differences among them.A registry hive is a group of keys, subkeys, and values in the registry that has a set of supporting files that contain backups of its data. The supporting files for all hives except HKEY_CURRENT_USER are in the %SystemRoot%\System32\Config folder on Windows NT 4.0, Windows 2000, Windows XP, Windows Server 2003, and Windows Vista. The supporting files for HKEY_CURRENT_USER are in the %SystemRoot%\Profiles\Username folder. The file name extensions of the files in these folders indicate the type of data that they contain. Also, the lack of an extension may sometimes indicate the type of data that they contain.
Jun 20, 2008 | Microsoft Windows Vista Ultimate Edition
159 people viewed this tip
David Payne
David Payne
