Tip & How-To about ASUS P5S800-VM Motherboard
P5s800-vm
Hi
in my system USB port is not working
please send the USB Drivers Data
thank full thank full to Asus System
regards
ASUS P5S800-VM Motherboard Logo
Hi, my system not working properly.
I don't think this is a BIOS problem. Sound more like you need to re-load windows and start from scratch. Make sure your USB is turned on in the BIOS.
Dec 25, 2009 | ASUS M2N-MX Motherboard
Can't install SimpleTech 160 gigabytes
The usb port in your compute dosent support usb 2 please change the port if your system is latest dont connect both the usb cables of the hdd cauz the latest system is with usb 2 and dosent need power if old system please connect the power usb first and then the data usb cable it should work
please also try to connect to another port of your pc if available
thanks and regards
DUSHAYaNT
Jan 03, 2009 | SimpleTech Signature Mini 160GB External...
p5s800vm
If you run XP , or Vista you don't need USB drivers . Purchase a PCI-USB card
Jul 03, 2008 | ASUS P5S800-VM Motherboard
A USB mouse will work but the PS/2 mouse failed. What causes it?
Hi melch, On the PS/2 mouse, chances are that the surface mounted fusible link/resistor supplying the +5VDC is open. It is normally very near the PS/2 port and marked [0] or labeled F???. This can be verified by measuring the absence/presence of +5 at pin 4 of the connector. In some cases, it is the I/O chip that gets damaged. Re "only two(2)USB port" aside from the 2 rear USB ports, the Asus CUV4X-C has another pair of USB connectors that are normally connected to the front panel of the casing. It is located very near the motherboard battery. Re "...prompting...high speed USB port...", normally by updating your OS (say XP to SP2) or downloading/installing latest VIA 4 in 1 Drivers should make your USB 2.0 compatible. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 23, 2007 | ASUS VIA Apollo Pro133A Chipset CUV4X-C...
2,096 people viewed this tip
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
