Tip & How-To about Electrolux Epic 6500 Vacuum
Electrolux Epic 6500: Trouble Shooting I
Electrolux Canister Vacuum Shuts Off During Use
This actually cover several models of Aerus and Electrolux canister vacuums. Models covered include: 2100, Epic 6000, Epic 6500, Aerus Lux 5500, Aerus Lux 7000, and Aerus Lux Legacy. Be aware that some of these models may still be under warranty. Any disassembly of those machines will void the warranty. Use of non-genuine bags also voids the warranty. Use only Home Solutions Aerus/Electrolux bags.
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Vacuums Logo
Unit turns off when any type of restiction to air intake. For example when unit is turned if hand is held in front of hose connection unit will turn off
Mar 04, 2011 | Electrolux Epic 6500 Vacuum
Bag full vacuum shut off. Is there a reset
You didn't mention the model, but with several Electrolux canister models, I'd say there's probably a problem with the control valve assembly inside the canister. This would need to be repaired at an authorized Aerus Electrolux store. If unsure where the nearest store is, use this link to locate one:
The tip on the following link covers other possible causes.
http://www.fixya.com/support/r7367127-electrolux_epic_6500_trouble_shooting
Jan 06, 2011 | Electrolux Epic 6500 Vacuum
eletrolux lux7000 manu and how to retract the power cord?
For the user's/owner's manual, go to the below link, click on the arrow below where it says "Older Models", click on Lux 7000, click on "download". If you want a service manual, they are only available to Aerus Electrolux stores.
For retracting the cord, try tipping vacuum up on it's back end and gently pulling and releasing cord. This will often cause it to retract. If not, keep in mind that the canister portion of this vacuum has a 7 year warranty on it, so depending on when you purchased it, the cordwinder may still be covered. The warranty does not cover normal wear and tear, or abuse. There are other things that will void the warranty.
Nov 26, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
Unfortunately alot of people buy this model because of the electrolux name, but it is actually made by eureeka. Aerus-Electrolux is the manufacturer of the high quality machines of our parents day.
Nov 04, 2007 | Electrolux EL7055A Bagless Canister Vacuum
electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Sep 15, 2007 | Electrolux Lux 5500 Canister Vacuum
2,693 people viewed this tip
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
