Tip & How-To about Cell Phones
Ipad tips :Use the magnifying glass
You Are Entering The Text, But You Realize You've Made A Mistake A Few Rows Back.Or to poke his Your Finger Or Try To Return To The Exact Location, Or Use A Magnifying Glass. Tap And Hold Your Finger In The Region, And A Magnifying Glass Appears, Allowing You To Adjust The Insertion Point.
Cell Phones Logo
Tension Problems
have to ask --are you sure that it is a tension problem
could be a needle /hook timing problem because if that is off it will also miss stitches
it can be off from worn parts and bushes
Mar 27, 2017 | Sewing Machines
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters only, not the lower case, and fails on numbers, returning #N/A. The upper case letters and most of the other characters work properly.
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
location of starter motor in 2001 dodge intrepid
Exact location depends on which engine / transmission is installed.
The starter will be basically alongside the engine, leading into the transaxle.
There will be a large, positive wire leading from the battery to the solenoid that's mounted to the starter.
This wire is about the diameter of my little finger. It's very large, and hard to miss.
Follow this wire, and there's the starter.
Disconnect the negative battery cable before poking around down there. There is enough current available straight from a charged battery to weld metal, cause fires, and create serious injury or damage.
Apr 08, 2014 | Vehicle Parts & Accessories
Rolleiflex sl35 mirror stuck in the open position and shutter won't release to send the mirror back down.
Try this: Give the shutter button a few quick, hard pokes with your finger. Don't be shy, you've got to give it a few good jabs. This can get the mirror unstuck. It's helped me before...
Mar 10, 2014 | Rollei Genuine Slr Sl35 Etc Front Body Cap
having trouble with the cursor,
I've also had the same problem. Try using your small finger to navigate to the exact letter.
Aug 07, 2009 | Samsung S8300 Ultra Touch platinium-red...
125 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
