Tip & How-To about Computers & Internet
How to instal turbov on studio1450
You can install turboc on studio 1450 laptop.
1:by installing dosbox u can install tc on windows7
2:u can install full screen tc on xp
download Turboc>open>copy the "TC" folder and past shortcut on desktop(this is on xp)
Computers & Internet Logo
how to run turboc in full screen in windows vista ultimate
Windows Vista And above doest not support full screen command window.. In order to run dos programs in full screen mode u can you use dosbox emulator which will be more convenient. Note that if you use pointers in your program it may not wok under vista directly.. If u run under the dosbox emulation it will work fine.. You can download dosbox from http://www.softpedia.com/get/Programming/Other-Programming-Files/DOSBox.shtml
Sep 22, 2009 | Microsoft Windows Vista Ultimate Edition
how to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
problem for installing turboc++4.5 in wista
ok man i too had teh same prob dont back to xp
Before going to the details u have to create a folder (any name will do). Here we name it as Turbo
Now , Type in the following commands after the Z prompt:
Now type d: to shift to d: prompt .
D: cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
D: cd Bin
D: TC or Tc.exe [This presents u the Turbo C++3.0 screen]
On the Turbo C++ goto Options>Directories>Change the source of TC to the source directory [D] ( i.e. virtual D: refers to original c:\Turbo\ . So make the path change to something like D:\TC\include and D:\TC\lib respectively )
In order to get the full screen use the key combination of Alt and Enter
When u exit from the DosBox [precisely when u unmount the virtual drive where Turbo C++ 3.0 has been mounted] all the files u have saved or made changes in Turbo C++ 3.0 will be copied into the source directory(The directory which contains TC folder)
It is a good idea to backup your files in the source directory prior to running DOSBox 0.72
For additional help go through the readme file located in the installation folder or look on the website of the DOSBox forum.
The above procedure has been successfully implemented on Windows Vista Ultimate 64 bit
IMP : Don't use shortcut keys to perform operations in TC because they might be a shortuct key for DOSBOX also . Eg : Ctrl+F9 will exit DOSBOX rather running the code .
Jun 17, 2009 | Microsoft Windows Vista Ultimate Edition
16 bit MS-Dos Subsystem Turbo C++ IDE The NTVDM CPU has encountered an illegal instruction cs:0000lp:flboop:of00640352 choose close to terminate the application
I too have a problem on my PC,when running the Turbo C programThe error message is:
16 bit MS Dos Sub system
turbo c++ IDE the NTVDM has encountered an illegal instruction.
At last i found the solution, and it is simple.
After installing your turboC follow the steps..
1) go to TC directory and open BIN.
2)In "BIN" folder you can find "tc.exe". Right click on "tc.exe" and click properties (and make sure that do not click on shortcut of TC.exe).
3)In properties there should be a tab called "screen", In that you will find "usage" option. There.. select "window" option instead of "full screen".
4) Then click "OK".
5) Now click "TC.exe".
6) It will open in window mode, if you want you can change full screen mode by pressing "ALT + Enter".
Thanks & Regards
Shravan reddy Konnela.
Jun 02, 2009 | Microsoft Windows XP Professional with...
turbo c doesnt have a full screen version on vista..
FOLLOWS THESE STEPS TO SOLVE THIS PROBLEM...
  1. Copy the “DOSBox0.72-win32-installer.exe” from http://www.download3k.com/Install-DOSBox.html
  1. Install it with default settings.
  2. Create a folder “Turboc” in your C:\> directory.
  3. Copy your turbo c folder such as “TC” in the folder “Turboc”. This is shown in the following diagram.
fifth.jpg?w=625&h=526<!Run the software you installed. Its icon is present on the your desktop.
  1. This will run the software, as shown in the fig:
first.jpg?w=573&h=507<!
Write these lines in the screen:
mount c c:\>Turboc
Press Enter
Following message will appear on the screen
Drive c is mounted as local directory c:\Turboc\
Now write:
C:
Press Enter
Now write:
cd TC
Press Enter,
Now write
cd bin
Press Enter,
Now write
Tc.exe
All these steps are shown in the following figure:
8.
Now following screen will appear:
10. Press Alt + Enter. Full screen mode of Turbo C will appear.
[updated]IMPORTANT : Don’t use shortcut Ctrl+F9 bcoz it is a shortcut for dos box to exit
Happy Coding
Jul 02, 2008 | Microsoft Windows Vista Ultimate Edition
174 people viewed this tip
David Payne
David Payne
