Tip & How-To about Nintendo Wii Console
How to access wireless internet in WII ?
First of all you need to know what is the Network name (SSID) and Password(security key) for your wireless network... Also make sure the firewall is disabled in your wireless router....Now, turn on the Wii...
Click the icon that looks like a house (home) on the Wii remote, you will see the Menu of your WII console...
Go to the settings > Select Internet connection settings > Select Wireless > Now select look for an Access Point in range...
You will see the list of available networks in range.... You must be able to see your network name among the list of wireless networks... Now select your network and select done...
Now it will ask you to enter the security settings... Enter your WPA or WEP key and select done...!
Thats it ! You are done...! Now it will test the Internet connection... After testing the connection, it will ask you to update the firmware, update the firmware and finish the process... You must be able to play the games online...
Nintendo Wii Console Logo
How to connect to wifi on pro 950
I found this on google. Hope this helps:
Q: I've tried to install the product's software for a wireless connection, but cannot complete the installation. What should I do? A: Do the following: Important: You'll need to know your network name (SSID) and network password before you can set up your product. If you don't know them, contact the manufacturer of your router or the person who set up your network.
If you know your security settings, continue with these steps:
  1. Reset the product's network settings. Press the home_button.gif home button, if necessary. Select Setup. Scroll down and select Restore Default Settings. Select Wi-Fi/Network Settings. You see a confirmation screen. Select Yes to reset the selected settings. (Select No if you want to cancel the operation.)
  2. Turn your router off and back on. Important: If your router is connected to other devices, you may need to re-establish the connection for the other devices on the network.
  3. Close all applications (including any screen savers, virus protectors, and firewall software) before you install the software.
  4. Uninstall the printer software (Windows only), then reinstall the printer software.
If the steps above for a wireless connection do not help, check the additional troubleshooting tips below, then try steps 1 through 4 again.
  • If you're setting up the printer for the first time, make sure you have the correct SSID (wireless network name) and if security is enabled, the wireless network password (WEP key or WPA passphrase). This information is stored in your network's router and you may be able to access it by logging onto the router from your computer and checking its setup screens. If you are unable to access the information, contact the person who set up your network or the manufacturer of your router or access point for details. (Epson will not be able to provide this information to you.) You'll need to know the SSID and wireless network password before you set up the printer.
    Note: The SSID and security key or passphrase are case sensitive. Be sure to correctly note uppercase, lowercase, and numeric/special letters.
  • If your wireless router or access point is set to not broadcast its Network name (SSID), you'll need to enter the SSID manually in the printer's setup software. If your wireless router or access point has wireless security enabled, you'll also need to know what kind of security it is using. Epson will not be able to provide this information to you. If you don't know this information, you'll need to contact the manufacturer of your router or the person who set up your network.
  • Make sure the product is within range of the wireless router or wireless access point.
  • Avoid placing the printer near a microwave oven, 2.4 GHz cordless phone, or large metal objects such as a filing cabinet.
  • Check to see if access restrictions, such as MAC address filtering, are set on the router or access point. If access restrictions are set, add your product's MAC address to your router's address list. If you're unsure on how to do this, contact the manufacturer of your router for instructions. To obtain your product's MAC address, print a network status sheet.
  • Disable any settings (such as AP Isolation, Client Isolation, or Privacy Separator) on your wireless router or access point that would prevent wireless devices from communicating with each other.
  • Make sure your system meets the requirements.
  • Make sure all applications (including any screen savers, virus protectors, and firewall software) are closed.
  • Make sure you have administrative rights or software installation privileges to your computer.
Nov 11, 2014 | Office Equipment & Supplies
Am installing a new Canon Printer and have been requested to include an Access Point Name/Network Name and Network Key. Am using a D Link Wireless Storage Router D I 624S. Can you assist ?.
The Network name usually referred to as SSID is the name of your wireless network...
The Network key is the password for your wireless network, usually referred to as security key...
The SSID and Password will usually printed at the bottom of the wireless router (in most of the models)
If you dont have them printed at bottom, then you need to open the router interface to get those information...
The Network name can be also see when you scan for wirelesss networks in range from any of your wifi enabled devices like laptop, iphone, ipod touch etc...
If you know the password you can use the same password...
Dec 09, 2010 | Computers & Internet
my husband bought a dlink router (it says dgl-4500 on it) and i cant figure out how to use it to get wireless internet for my new laptop....i have three "codes" he wrote down- a "router pass", a "network name" and a "security key"...none seem to work...totally lost and NOT computer saavy!
Router password is the password to access the router settings.
SSID is the network name. When you try to connect to the wireless network on your laptop, you will see this network name.
If your network is secured network then it will ask you for the network key or the password. You need to enter the ' security key '.
Click Here for step by step by instructions
Sep 11, 2010 | D-Link DGL-4500 Wireless Router
How do I lock my Dell TruMobile 2300 wireless router to keep the neighbors from getting access to my wireless internet connection
press win key + r
under run type cmd
on the command prompt type ipconfig
not down your defaut gateway.
type it in your web browser, and then enter the correct user name and password for the router.(i u dont know the user name leave it blank or try admin for both user name and password or its combination o call dell for it)
Create a unique password on your router : Once you have logged into your router, the first thing you should do to secure your network is to change the default password* of the router to something more secure.
This will prevent others from accessing the router and you can easily maintain the security settings that you want. You can change the password from the Administration settings on your router’s settings page. The default values are generally admin / password.
Change your Network’s SSID name:
The SSID (or Wireless Network Name) of your Wireless Router is usually pre-defined as "default" or is set as the brand name of the router (e.g., linksys). Although this will not make your network inherently* more secure, changing the SSID name of your network is a good idea as it will make it more obvious for others to know which network they are connecting to.
This setting is usually under the basic wireless settings in your router’s settings page. Once this is set, you will always be sure that you are connecting to the correct Wireless network even if there are multiple wireless networks in your area. Don’t use your name, home address or other personal information in the SSID name.
This is sufficient to secure your router from other to use it.
Aug 11, 2010 | Dell TrueMobile 2300 Wireless Router...
can't connect the artisan 800 to our wireless network
To add the printer to your wireless network, you need to know the name (SSID)
of your wireless network. If it has security enabled, you also need to know the
WEP key or passphrase. Write down the SSID and WEP key or passphrase below:
■ Network name (SSID): _________________________________________
■ WEP key or passphrase: _________________________________________
Note:
If the WEP key is either 5 or 13 characters, it’s ASCII. If the WEP key is either 10 or 26
characters, it’s hexadecimal. The default WEP key is usually 1.
If your passphrase contains upper- or lowercase letters, be sure to note it correctly.
The printer supports the following wireless security modes: WEP 64, WEP 128, and
WPA-PSK.
If you don’t know your wireless network name (SSID) or WEP key or passphrase,
contact the person who set up your wireless network before you begin.
Insert the printer software CD.
2. Windows Vista®: If you see the AutoPlay window, click Run Epsetup.exe.
When you see the User Account Control screen, click Continue.
Windows® XP: When you see the Software installation screen, continue with
step 3.
Mac OS® X: Double-click the icon.
3. Click Install.
1.Make sure that the printer is turned on.
2. When you see the FireWall Warning screen, click Next.
3.Make sure you connected the Ethernet cable
Oct 09, 2009 | Epson Artisan 800 All-In-One InkJet...
1,539 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
